wiki3443: Bspdown_lippertcoreexpress (Version 5)
LiPPERT CoreExpress Board Support Package#
This BSP supports the LiPPERT CoreExpress board.
Releases#
QNX Neutrino Trunk#
Date Version Prerequisites Installation Notes Release Notes License(s) Support Provider Download Source Tag
Coming Soon! trunk QNX Momentics Trunk Trunk Generic Notes here Apache II and QDL Experimental QNX Coming Soon! Coming Soon!
QNX Neutrino 6.4.0#
Coming Soon! trunk QNX Momentics 6.4.0 6.4.0 Generic Notes here Apache II and QDL Experimental QNX Coming Soon! Coming Soon!
Fastboot IPL Source
Features#
Feature Planned Availability Format Notes
High Definition Audio Completed BIN .
IPL Completed BIN “Cold Start” IPL, programmed to EEPROM.
Startup Completed SRC .
Serial Completed SRC .
Flash Completed SRC Intel FWH NOR flash .
Ethernet Completed BIN Intel 82551QM Ethernet Controller.
EIDE Completed BIN .
SMbus Resource Manager Completed SRC .
USB Completed BIN EHCI and UHCI.
Graphics Completed BIN .
MMC / SD Completed SRC .
PCI / PCIe Completed SRC PCIe devices are supported only in PCI legacy mode.
Some of these drivers are commented out in the default buildfile. To use the drivers in the target hardware, you'll need to uncomment them in your buildfile, rebuild the image, and load the image into the board.
QNX Neutrino Trunk Change History#
Trunk#
  • Same as QNX Neutrino 6.4.0 for LiPPERT CoreExpress Trunk
QNX Neutrino 6.4.0 Change History#
Trunk#
  • Created from QNX Neutrino 6.3.2 BSP for Intel Crownbeach 1.0.0
  • Built using the latest 6.4.0 toolchain
Known Issues#
Inactive Tab Versions Inactive Tab - left sideAssociations Inactive Tab - left sideAttachments Active Tab - left sideBack LinksActive Tab - right side
