Aaron Cripps
02/20/2008 10:19 AM
post5151
First of all, when I run hide-gnu.sh as an external tool from within Momentics there are a lot of failed touch commands
because for some reason it's picking up the "QNX Neutrino" dir as
"QNX" and "Neutrino" dirs. The workaround I've been using is to rename it to something that won't be mistaken (i.e.
QNX_Neutrino) and then renaming it back ... but, there has to be a better way. I didn't see anything in the script that
would allow me to do that since it's apparent that QNX and Neutrino are being held in the dir var at different times.
Second, when I try doing a make -j3 (after I do make -j3 hinstall) at the CLI instead of within momentics, I get an
Error 2 failure (DNDEBUG command not found) which means there's no DNDEBUG env. var. What should I set this to?
Adittionally, I have a multi-core processor and would like to use it to its full potential, so a
make -j3 <target> would be fantastic, but according to the man page, the last -j option is the one used by default. I've
noticed that each makefile within the Neutrino source uses make -j 1 <targets> ... is there a special reason for that,
and is there a way I can change it (if it's safe)?
Last, but not least, the target machine that I'm building for has two processors, an arm7 and an arm9 ... how would I
cross-compile the Operating System (kernel/procmgr) for the target using momentics or the command line?
That's all I've got for now, thanks in advance for looking at this all ... if I have any more questions I'll be back.
Cheers,
-Aaron
