Trackers
Trackers
Forum Topic - Momentics 6.4.1 refuses to connect to qconn: (6 Items)
Hi there,
for the last 19 hours (really!) I tried to connect Momentics 6.4.1 running on Debian Linux 64bit (kernel 2.6.34) to a
Neutrino641 target which is running in VMWare.
I can ping the guest from the host and the host from the guest. I can telnet to qconn on port 8000. In short, the
network is running pretty fine. The only problem is, whenever I try to create a new target in Momentics: Add new target-
>new QNX->enter the IP->click Finish - Momentics says: not connected.
I get no error whatsoever. I'm just not connected. It drives me really crazy!
Under Windows7 the same configuration works flawlessly but I cannot use Windows in this case, because I have to use
Momentics for a course in university and all the additional libs I get are for linux hosts only. Right now this libs are
 NOT used. I have a unchanged default installation of Momentics, so no possible errors from the external libs.
Any help, any idea is greatly appreciated.
Thanks a lot in advance.
Max
Re: Momentics 6.4.1 refuses to connect to qconn
A firewall issue on Linux side?
Try the vmware utility "vnetsniffer" to see how the connection is established on Windows vs. Linux.
Hi and thanks for your answer.
I forgot to mention that there is no firewall at all.
As I said, I can communicate with the Neutriono installation by any other means.
Nevertheless thank you.
Regards
Max
Maybe stupid but did you check if you have extra spaces in the target IP
address in the IDE?
> Regards
> Max
> http://community.qnx.com/sf/go/post70978
yes, I checked it several times.
Meanwhile I found out that Momentics doesn't like 64bit Linux (maybe it's the JavaVM). I did an install on 32bit Linux
(same machine, same kernel version) and all is well in Whoville.
Thank you for you answer.
Regards
Max
> address in the IDE?
