Forum Topic - PowerEdge R200: (7 Items)
PowerEdge R200
Trying to load QNX4.25 on too a PowerEdge R200
Fsys.atapi is crashing just after it starts loading the rest of the OS.
Dave
RE: PowerEdge R200
How is the IDE interface setup in the BIOS? If it is setup as AHCI, it
won't work. It has to be set to compatible mode. Please also supply the
'show_pci -vv' output.
Thanks, Hugh.
From: dave allamby [mailto:community-noreply@qnx.com]
Sent: Tuesday, October 06, 2009 8:09 PM
To: qnx4-community
Subject: PowerEdge R200
Dave
QNX4 Community Support
http://community.qnx.com/sf/go/post39469
Re: PowerEdge R200
Hugh,
Have to figure out how to load the QNX first...the CD-ROM drive is SATA
too so the product suite wont boot either.
I took the drive out of Dell 860 and dropped it into new machine to
test. Maybe I can do something in the boot image.
The BIOS only allows ATA mode.
Dave
> Thanks, Hugh.
> To: qnx4-community
> Dave
> http://community.qnx.com/sf/go/post39492
Re: PowerEdge R200
Hugh,
The atapi driver wont start, so dont have anyway to dump show_pci
output....Tried creating a stripped
down .boot with Dev and Dev.ser running but the boot process does not
seen to allow piping so cant pipe output of show_pci to serial line
...is the source for show_pci available could mod it to write directly
to /dev/ser1
Dave
> Thanks, Hugh.
> To: qnx4-community
> Dave
RE: PowerEdge R200
Do you have QNX 6.4? If so, I can send you a boot images for QNX6 to
boot from a USB stick.
Hugh.
Sent: Friday, October 16, 2009 1:26 AM
To: qnx4-community
Subject: Re: PowerEdge R200
Hugh,
to /dev/ser1
Dave
the
> Thanks, Hugh.
> To: qnx4-community
OS.
> Dave
http://community.qnx.com/sf/go/post40090
Re: PowerEdge R200
Hugh
No I have not upgraded our software to QNX6 and I have no licenses for it.
I am still trying to get a moded version of show_pci to run and dump its
output directly to the serial port.
Runs fine from command prompt but seems to halt after detecting PCI
version when stuck in the boot file
Dave
> Hugh.
> To: qnx4-community
> Hugh,
> to /dev/ser1
> Dave
> the
>> Thanks, Hugh.
>> -----Original Message-----
>> To: qnx4-community
> OS.
>> Dave
> http://community.qnx.com/sf/go/post40102
Re: PowerEdge R200
Hugh,
Update, found the show_pci source
Dave
> Thanks, Hugh.
> To: qnx4-community
> Dave
