Forum Topic - VM and memory:
VM and memory
Help.  I am using the canned QNX 6 for VM.  It is apparently set for 3G of memory.  When I up the available memory in VM
, QNX still uses 3G.  Is there any easy way to bump the memory that QNX sees and ** uses **.  Thanks much.
Re: VM and memory
Try passing -x to startup-bios to enable PAE
VM, QNX still uses 3G.  Is there any easy way to bump the memory that QNX sees and ** uses **.  Thanks much.
> http://community.qnx.com/sf/go/post113748
> To cancel your subscription to this discussion, please e-mail general-community-unsubscribe@community.qnx.com
Re: VM and memory
Colin - thanks. Do I need to rebuild startup-bios or is it called in a way that I can modify the args without a rebuild?
 If I need to rebuild startup-bios, is that all I need to do (change, recompile and put it in /boot/sys) or ??? Any
cautions?
----- Original Message -----
To: general-community@community.qnx.com
Sent: Wednesday, April 29, 2015 6:05:27 AM
Subject: Re: VM and memory
> Help. I am using the canned QNX 6 for VM. It is apparently set for 3G of memory. When I up the available memory in VM,
General
http://community.qnx.com/sf/go/post113753
Attachment: HTML sf-attachment-mime29705 1.73 KB
Re: VM and memory
You don't need to modify startup-bios, but you need to run mkifs to
regenerate the boot image, then transfer that onto the image.
You'll need to become familiar with the docs for startup-bios and mkifs,
and you'll have to locate the build file used for your current system.
> a way that I can modify the args without a rebuild?  If I need to
> put it in /boot/sys) or ???  Any cautions?
> *From: *"Colin Burgess" <community-noreply@qnx.com>
> *To: *general-community@community.qnx.com
> *Sent: *Wednesday, April 29, 2015 6:05:27 AM
> *Subject: *Re: VM and memory
> 3G of memory.  When I up the available memory in VM, QNX still uses
> > General
Attachment: HTML sf-attachment-mime29711 3.63 KB
