Forum Topic - Simple project question: (3 Items)
I've installed the QNX Momentics IDE on my windows xp laptop and am trying to compile and link my source code C++ and
run this on the Momentics QNX target IDE that comes with the install.  I have some questions:
1-I need to build a C++ library first in order to compile my C++ source code.  is it possible to compile my C++ library
source code on the QNX target RTOS that comes with the Momentics IDE?  The library has unix scripts that should work if
I can do this.   If not can I use the QNX Momentics CD as a bootable disk and setup QNX on VMWare on my laptop or on
another server?
2-how do I start the qconn process on the target QNX target RTOS that comes with the Momentics IDE?  I see that there is
 a target QNX RTOS there under the folder: D:\QNX632\target\qnx6.  I need to start the qconn process so that I can
connect my project to the target RTOS to run the binary on this target system.
3-How do I execute the commands that I see on the QNX target RTOS that comes with momentics?  I tried phindows to my
laptop and it won't connect.
Sorry about the simple questions but I'm very new to QNX..
Thanks for any help.
Re: Simple project question
to compile and link my source code C++ and run this on the Momentics QNX
code.  is it possible to compile my C++ library source code on the QNX
that should work if I can do this.   If not can I use the QNX Momentics CD
as a bootable disk and setup QNX on VMWare on my laptop or on another
server?
You can build library on the same Windows machine with qnx tools which
use cross-platform compilers.
comes with the Momentics IDE?  I see that there is a target QNX RTOS there
so that I can connect my project to the target RTOS to run the binary on
this target system.
qconn process should be started on target. You need to create os image
and load it on the target or just install momentics for neutrino from cd
on the vmware vm.
comes with momentics?  I tried phindows to my laptop and it won't connect.
You cannot execute them on your laptop (assuming it is Windows).
"target" directory contains files that required to build an OS image.
Use instructions from step 2.
There is online documentation. There is very good tutorial: Ten steps to
your first qnx program
(http://www.qnx.com/developers/docs/6.3.2/momentics/quickstart/about.html)
> http://community.qnx.com/sf/go/post8540
OK I'm going to boot into QNX momentics for neutrino with VMWare and see if  I can compile my source code into the
library I need on QNX.
Steve Thompson
