05/28/2008 3:22 PM
post8540
I've installed the QNX Momentics IDE on my windows xp laptop and am trying to compile and link my source code C++ and
run this on the Momentics QNX target IDE that comes with the install. I have some questions:
1-I need to build a C++ library first in order to compile my C++ source code. is it possible to compile my C++ library
source code on the QNX target RTOS that comes with the Momentics IDE? The library has unix scripts that should work if
I can do this. If not can I use the QNX Momentics CD as a bootable disk and setup QNX on VMWare on my laptop or on
another server?
2-how do I start the qconn process on the target QNX target RTOS that comes with the Momentics IDE? I see that there is
a target QNX RTOS there under the folder: D:\QNX632\target\qnx6. I need to start the qconn process so that I can
connect my project to the target RTOS to run the binary on this target system.
3-How do I execute the commands that I see on the QNX target RTOS that comes with momentics? I tried phindows to my
laptop and it won't connect.
Sorry about the simple questions but I'm very new to QNX..
Thanks for any help.
