10/16/2009 12:55 PM
post40153
Hugh
No I have not upgraded our software to QNX6 and I have no licenses for it.
I am still trying to get a moded version of show_pci to run and dump its
output directly to the serial port.
Runs fine from command prompt but seems to halt after detecting PCI
version when stuck in the boot file
Dave
Hugh Brown wrote:
> Do you have QNX 6.4? If so, I can send you a boot images for QNX6 to
> boot from a USB stick.
> Hugh.
> From: dave allamby [mailto:community-noreply@qnx.com]
> Sent: Friday, October 16, 2009 1:26 AM
> To: qnx4-community
> Subject: Re: PowerEdge R200
> Hugh,
> The atapi driver wont start, so dont have anyway to dump show_pci
> output....Tried creating a stripped
> down .boot with Dev and Dev.ser running but the boot process does not
> seen to allow piping so cant pipe output of show_pci to serial line
> ...is the source for show_pci available could mod it to write directly
> to /dev/ser1
> Dave
> Hugh Brown wrote:
>> How is the IDE interface setup in the BIOS? If it is setup as AHCI, it
>> won't work. It has to be set to compatible mode. Please also supply
> the
>> 'show_pci -vv' output.
>> Thanks, Hugh.
>> -----Original Message-----
>> Sent: Tuesday, October 06, 2009 8:09 PM
>> To: qnx4-community
>> Subject: PowerEdge R200
>> Trying to load QNX4.25 on too a PowerEdge R200
>> Fsys.atapi is crashing just after it starts loading the rest of the
> OS.
>> Dave
>> QNX4 Community Support
>> http://community.qnx.com/sf/go/post39469
>> http://community.qnx.com/sf/go/post39492
> http://community.qnx.com/sf/go/post40090
> http://community.qnx.com/sf/go/post40102
