04/29/2015 5:01 PM
post113760
You don't need to modify startup-bios, but you need to run mkifs to
regenerate the boot image, then transfer that onto the image.
You'll need to become familiar with the docs for startup-bios and mkifs,
and you'll have to locate the build file used for your current system.
On 2015-04-29 11:28 AM, community-noreply@qnx.com wrote:
> Colin - thanks. Do I need to rebuild startup-bios or is it called in
> a way that I can modify the args without a rebuild? If I need to
> rebuild startup-bios, is that all I need to do (change, recompile and
> put it in /boot/sys) or ??? Any cautions?
> *From: *"Colin Burgess" <community-noreply@qnx.com>
> *To: *general-community@community.qnx.com
> *Sent: *Wednesday, April 29, 2015 6:05:27 AM
> *Subject: *Re: VM and memory
> Try passing -x to startup-bios to enable PAE
> On 2015-04-27 5:42 PM, Terry Laughlin wrote:
> > Help. I am using the canned QNX 6 for VM. It is apparently set for
> 3G of memory. When I up the available memory in VM, QNX still uses
> 3G. Is there any easy way to bump the memory that QNX sees and **
> uses **. Thanks much.
> > General
> > http://community.qnx.com/sf/go/post113748
> > To cancel your subscription to this discussion, please e-mail
> general-community-unsubscribe@community.qnx.com
> http://community.qnx.com/sf/go/post113753
