Forum Topic - Memory Management: (6 Items)
Memory Management
Hello ,
My Hardware is PPC405 implemented in Virtex4 FPGA .
I'm using the procnto400 micro-kernel and the ml410 bsp downloaded from this site.
I have a question about the memory management in the kernel in general and in the relevant implementation in particular
I assume and correct me if i'm wrong that the kernel and the bsp operates in virtual mode (according to ppc reference
guide when MMU present the operating mode is virtual ).
In the bsp there are couple routines that set and activate the i-cache and the d-cache on the ram .
I assume and again correct me if i'm wrong that this is done for speeding system startup , because when the system is up
 the mmu takes place of memory including caching management.
1.Can anybody direct me to where the qnx memory model is described
anything more detailed than : http://www.qnx.co.jp/developers/docs/6.4.0/neutrino/sys_arch/proc.html#MEMMAN.
2.And can anybody describe the MMU interface and how is the TLB filled and when in kernel or in the bsp ?
3.Can I control the caching attributes in the TLB entries (the four most significant bits in the TLBLO )
Attachment: PDF PowerPc Processor Reference Guide.pdf 7.84 MB
Re: Memory Management
The startup program runs in real mode, but once the kernel has initialized
everything else is virtual.
up the mmu takes place of memory including caching management.
Correct.
There isn't anything more for user facing documentation. There
are:
http://community.qnx.com/sf/wiki/do/viewPage/projects.core_os/wiki/Vmm_data_structures
http://community.qnx.com/sf/wiki/do/viewPage/projects.core_os/wiki/Vmm_algorithms
http://community.qnx.com/integration/viewcvs/viewcvs.cgi/trunk/services/system/doc/mm-cpu-specific?root=coreos_pub&rev=153052&system=exsy1001&view=markup
which talk about the internal data structures.
> 2.
The TLB is filled only by the kernel. This is done in the TLB miss exception
handling routines (aside from some corner cases).  That code is in
services/system/ker/ppc/400/vm400.s. Look for the "tlb_miss" macro.
If you do a mmap() with PROT_NOCACHE set, you'll turn on the I and G bits
(if PROT_EXEC is on, the G-bit will be left off). If you need more control
than that, you can use the shm_ctl_special() API with the PPC_SPECIAL_*
macros (defined in <ppc/cpu.h>) to control the bits directly at the cost
of making your code not portable to other architectures.
Thank you very much for the detailed response .
A few more question :
1.When does the caching (I+D) initialization done ? Is it done before the startup program ?
Can i control it for performance evaluations only (wirte 0 to the iccr and dccr registers should do it ,no?)
2.the cpu_startup calls cpuconfig1 that initializing i+d caches and its happens before the startup program
is this the place where the caches are initialized
3. what is the first thing that runs when i start the bsp image ?
there is _main() routine in my startup/ppc directory that runs cpu_starup and than the startup program    main,  is this
 the first entry point of the bsp ?
The startup program does it during cpuconfig1(), as you've noted, which runs
very early on in the process. Some IPL's/rom monitors also will also enable
the cache before startup is invoked.
You might be able to get startup to run with the caches off, but the OS itself
will not operate properly unless they're enabled and properly initialized.
This is all part of the startup program - the cpuconfig1() routine does
get invoked before the board specific portion controlled by the main()
routine gets run.
this the first entry point of the bsp ?
The _start symbol in lib/startup/ppc/cstart.s is where execution begins
in the image, but it does very little before transferring control to
the _main() routine.
Brian Hello ,
Thank you again.
Your answers fill me a lot of blanks that i have .
You said :"You might be able to get startup to run with the caches off, but the OS itself
                 will not operate properly unless they're enabled and properly initialized."
I'm trying to do just that to check the caches influence on the startup program , more than that i inserted simple loop
in the beginning of the startup main that runs for 10 sec and want to check the time with and without cache.
I modified the ppcv_cpuconfig1_400 routine, once no to do anything and once to write 0 at the iccr and the dccr regs .
Nothing that i do seems to influence the performance of the 10 sec loop, the time remains the same with registers set or
 cleared .
Thank you again for you thorough answers they help me a lot .
Vadim.
I tried the attached code on a real 405 (200MHz). The call to timing_test()
was inserted just before the print_syspage() in main.c. It reported:
	loop time with caches on/off=42/435
which indicates a 10-fold decrease in performance of the loop with
the caches off.
On Wed, Jan 28, 2009 at 09:39:57AM -0500, Vadim Malenboim wrote:
> Brian Hello ,
> Thank you again.
loop in the beginning of the startup main that runs for 10 sec and want to check the time with and without cache.
or cleared .
> Vadim.
> http://community.qnx.com/sf/go/post20919
Attachment: Text tryme.c 1.68 KB
