Middleware, development tools, realtime operating system
software and services for superior embedded design
‹ QNX.com
Home
Project Categories
Projects
Community Search
Search Wiki Pages Project: QNX Operating System     Wiki > Vmm_data_structures > View Wiki Page
wiki1321: Vmm_data_structures
base memory object
The object structure is shared between both the pathmgr and memmgr components of procnto. They mostly keep to themselves, but there were a couple of places where interface breaking goes on - these are marked with comments in the source.
struct mm_object {
	struct object_header        hdr;
	struct pathmgr_stuff {
		 time_t                  mtime;
		 mode_t                  mode;
		 uid_t                   uid;
		 gid_t                   gid;
	}       pm;
	struct memmgr_stuff {
		struct proc_mux_lock    *mux;
		struct pa_quantum       *pmem;
		struct pa_quantum       **pmem_cache;
		struct mm_object_ref    *refs;
		struct pa_restrict      *restrict;
		off64_t                 size;
		unsigned                flags;
	}       mm;
The pm fields are for use by path manager.
mux
For locking/unlocking the memory object via the proc_mux_unlock functions.
pmem
The head of the list of physical memory for the object.
pmem_cache
Used for optimization purposes while walking the pmem list
refs
The head of the list of address spaces that are currently referencing this object.
restrict
When allocating physical memory for this object, the memory has to obey this restriction list.
size
The size in bytes of the object.
flags
Various flags for the object - some flags are common across all the types of memory objects, some flags are unique to each different type.
OBJECT_MEM_ANON
struct mm_object_anon {
	struct mm_object    mem;
OBJECT_MEM_SHARED
struct mm_object_shared {
	volatile unsigned   name_refs;
	unsigned            special;
	intptr_t           vaddr;
name_refs
This should really be a pathmgr thing, but then all the objects would have the space allocated. It's the number of open file descriptors for the object.
special
This holds the value of the special parameter of the shm_ctl_special function.
vaddr
For shared objects using global addresses (e.g. ARM above 32M), this field holds the base address of the object.
OBJECT_MEM_FD
struct mm_object_fd {
	int                 fd;
	time_t              ftime;
	ino_t               ino;
	dev_t               dev;
	char                *name;
	unsigned            pending_dones;
fd
The file descriptor obtained from _IO_MMAP that procnto uses to read/write to the backing file for the object.
ftime, ino, dev
These values are obtained by a stat of the file and are used by the memmgr to determine when the underlying file has been modified.
name
The debugging name of the object.
pending_dones
used to prevent a race condition when freeing the object.
OBJECT_MEM_TYPED
struct mm_object_typed {
	struct mm_object_shared shmem;
	char                    *name;
mm_aspace (ADDRESS)
struct mm_aspace {
	struct mm_map_head          map;
	struct  {
		uintptr_t       vmem;
		uintptr_t       data;
		uintptr_t       stack;
		uintptr_t       memlock;
		uintptr_t       rss;
	}                           rlimit;
	OBJECT                      *anon;
	struct _memmgr_rwlock       rwlock;
	unsigned                    fault_owner;
	unsigned                    flags;
	uintptr_t                   tmap_base;
	size_t                      tmap_size;
	struct cpu_mm_aspace        cpu;
map
Head of the vaddr to struct mm_map conversion structure.
rlimit
Holds the current usage various rlimit pieces.
anon
Pointer to the OBJECT_MEM_ANON object for the address space.
rwlock
Used for reader/writer locks on the address space.
fault_owner
In some cases we could have an address space locked and be performing some request which causes a page fault to occur. Normal fault handling will attempt to lock the address space again. This field is used by the fault handling code to recognize when the faulting thread is a memmgr one that already had the aspace locked, so the fault code doesn't have to do so again (avoiding a deadlock).
flags
Various aspace related flags.
tmap_base, tmap_size
The memmgr sometimes has to read/write data into physical memory that it currently does not have a mapped virtual address. These fields give the base and size of the last temporary mapping region that we used. If no mmap's have been done in the meantime, we can reuse that region, saving us from having to look for a new one.
cpu
All the CPU specific address space fields.
mm_mmap
struct mm_map {
	struct mm_map           *next;
	struct mm_object_ref    *obj_ref;
	off64_t                 offset;
	struct {
		struct mm_map           **owner;
	}						ref;
	uintptr_t               start;
	uintptr_t               end;
	int                     reloc;
	unsigned                mmap_flags;
	unsigned                extra_flags;
	unsigned short          last_page_bss;
	uint8_t                 spare;
	volatile uint8_t        inuse;
next
Pointer to the next squentially higher mapping in this aspace.
obj_ref
Pointer to the struct mm_object_ref for this mapping.
offset
The offset from the start of the object for this mapping.
ref.next
The next mapping in this address space that references the same object as this one.
ref.owner
A pointer to a pointer of previous mapping in this address space that references the same object as this one.
start
The starting virtual address of this mapping.
end
The last valid virtual address of this mapping.
mmap_flags
The combination of the mmap flags and prot parameters.
reloc
The debugging relocation.
extra_flags
Some other additional flags for this mapping.
last_page_bss
With a MAP_ELF mapping, the memmgr code determines if the final page of a mapping would go beyond the end of the filesz field of the ELF segment. In that case, the last_page_bss field indicates how many bytes at the end of the page should be zeros.
inuse
Whether there are still people pointing at this structure, even though the aspace has been unlocked.
mm_object_ref
struct mm_object_ref {
	struct mm_object_ref    *next;
	struct mm_aspace        *adp;
	OBJECT                  *obp;
	struct mm_map           *first_ref;
	int                     fd;
next
Pointer to the next struct mm_object_ref for the object.
adp
Pointer to the address space for this reference.
obp
Pointer to the actual object for this reference.
first_ref
Pointer to the head of the linked list of struct mm_maps that reference the given object in the given address space.
fd
The user file descriptor that was passed into mmap for the mapping.
pa_quantum
struct pa_free_link {
	struct pa_quantum   *next; // must be first entry
	struct pa_quantum   **owner;
struct pa_inuse_link {
	_Uint32t            qpos;
struct pa_quantum {
	union {
		struct pa_inuse_link    inuse;
		struct pa_free_link     flink;
	}           u;
	_Int32t     run;
	_Uint16t    blk;
	_Uint16t    flags;
u.flink
Doubly linked list used when the quantum is not in use.
u.inuse
Singly linked list used when quantum is in use.
run
There's one pa_quantum for each page of system ram in the system. These are collected into contiguous runs - either allocated or unallocated. For the first quantum in a run, the run field indicates the number of quantums in the run. The last quantum has the same value in it's run field, but negated. The quantums in the middle have zero for the field.
blk
This field holds the block number for the quantum. A block is a contiguous sequence of system ram.
flags
Various flags.
pa_quantum_fake
struct pa_quantum_fake {
	struct pa_quantum   q;
	paddr_t             paddr;
Since the physical memory list of an object must be made up of quantums, and we only allocate enough pa_quantum's to cover the system ram for a box, something special has to be done when the user requests a direct physical mapping. In those cases, we create a pa_quantum_fake. These differ from a normal pa_quantum in that they have a paddr field attached to them to give the physical address (normal pa_quantum's obtain the physical address from information in the block head structure) and the fact that no matter how many pages the mapping is for, only one pa_quantum_fake structure is allocated, as opposed to the array of pa_quantum's that would be used to cover the same amount of physical memory. Code can tell the difference between the two by the fact that pa_quantum_fake's blk field is set to PAQ_BLK_FAKE.
memmgr_ds.jpg [Vmm_data_structures/memmgr_ds.jpg]
