wiki3772: Nto640AtmelAt91sam9260EKEVBTrunkReleasenotes (Version 5) | ||
Release Notes for the QNX Neutrino 6.4.0 BSP for Atmel AT91SAM9260-EK Board#System requirements#Target system#
Host development system#
Getting Started#Step 1: Connect your hardware#Connect the DEBUG port of the AT91SAM9260 board to the first serial port of your windows machine. Install the SAM-BA application provided by Atmel. Connect the board with Windows Machine using USB Cable.Step 2: Build the BSP#You can build an OS image from the source code or the binary components contained in a BSP package. For instructions about building an OS image, please refer to the chapter Working with a BSP in the Building Embedded Systems manual. After Building the BSP three bin files will be created in images directory.*ifs-at91sam9260.bin *ipl-at91sam9260.bin *ipl-ifs-at91sam9260.bin mkflashimage script creates a combined IPL/IFS image as ipl-ifs-at91sam9260.bin The mkflashimage script: #!/bin/sh # script to build a binary IPL and boot image for ATMEL AT91SAM9XX Evaluation Kit board # NOTE the image (ipl-ifs-at91sam9xx.bin) must be built as binary, i.e. [virtual=armle,binary] in the buildfile set -v # Convert IPL into BINARY format ${QNX_HOST}/usr/bin/ntoarm-objcopy --input-format=elf32-littlearm --output-format=binary -R.data ../install/armle/boot/sys/ipl-at91sam9260 ipl-tmp-at91sam9260.bin # Pad BINARY IPL mkrec -s4k -ffull -r ipl-tmp-at91sam9260.bin > ipl-at91sam9260.bin # Combine the BINARY IPL with the BINARY OS Image cat ./ipl-at91sam9260.bin ./ifs-at91sam9260.bin > ipl-ifs-at91sam9260.bin # Cleaning up temporary files rm -f *tmp* Step 3A: Download the Bootable IFS image.#The Boot Program integrates different programs that manage download and/or upload into the different memories of the product. First, it initializes the Debug Unit serial port (DBGU) and the USB High Speed Device Port.
Install and setup SAM-BA#1. Install "AT91-ISP v1.12.exe" . 2. Intall "ActiveTcl8.5.5.0.287690-win32-ix86-threaded.exe" i.e.TCL environment which is used by SAM-BA (any other TCL environment can also be used) . 3. Connect serial cable with windows machine, and use any serial port application such as teraterm or hyperterminal, and attach it with COM device, with baud rate set as 115200. 4. Restart the board, hyperterminal will be showing following message . RomBOOT > 5. Connect usb cable with windows machine, It will prompt with a new usb hardware found message, and will try to install the corresponding driver. 6. Check device has enumerated properly by looking into device manager . 7. Start SAM-BA 2.6 with \usb\ARM0 as connection. Loading the IFS image using SAM-BA#
Now on your terminal you will see output as follows: RomBOOT > QNX Neutrino Initial Program Loader for ATMEL AT91SAM9260-EK Commands: Press 'D' for serial download, using the 'sendnto' utility Press 'F' to Boot an OS image from SPI/SERIAL flash ATMEL AT45DB642D/AT45DCB008D SPI Flash detected. QNX IFS image detected on page: 00000004 Offset: 000003A0 Size: 005C2240 ######################################################Done found image, calling image setup... image_setup OK, calling image start... PIO init : DBGU, USART, NAND, CPU0: Dcache: 256x32 WB CPU0: Icache: 256x32 CPU0: 41069265: arm926 rev 5 100MHz elf_map: 1M va=fe000000 pa=20100000 sz=00100000 elf_map: 1M va=fe000000 pa=20100000 sz=00100000 Header size=0x0000009c, Total Size=0x000004e0, #Cpu=1, Type=4 Section:system_private offset:0x000001f0 size:0x00000068 syspage ptr user:fc404000 kernel:fc404000 cpupage ptr user:fc4047e0 kernel:fc4047e0 spacing:84 kdebug info:00000000 callback:00000000 boot pgms: idx=0 0) base paddr:20110000 start addr:fe03d838 ramsize:00000000 pagesize:00001000 Section:qtime offset:0x00000148 size:0x00000060 boot:00000000 CPS:00000000002faf08 rate/scale:320000000/-15 intr:1 Section:callout offset:0x000000a0 size:0x00000048 reboot:fc404658 power:fc404678 timer_load:fc40468c reload:fc4046b4 value:fc4046e0 0) display:fc404700 poll:fc404724 break:fc404748 1) display:00000000 poll:00000000 break:00000000 Section:cpuinfo offset:0x000001a8 size:0x00000020 0) cpu:41069265 flags:40000000 speed:00000064 cache i/d:1/0 name:53 Section:cacheattr offset:0x000004a0 size:0x00000040 0) flags:32 size:0020 #lines:0100 control:fc4044e0 next:255 1) flags:11 size:0020 #lines:0100 control:fc404534 next:255 Section:meminfo offset:0x000004e0 size:0x00000000 Section:asinfo offset:0x00000320 size:0x00000140 0000) 0000000000000000-00000000ffffffff o:ffff a:0010 p:100 c:00000000 n:21 0020) 0000000020000000-0000000023ffffff o:0000 a:0017 p:100 c:00000000 n:28 0040) 0000000000000000-00000000ffffffff o:ffff a:0010 p:100 c:00000000 n:21 0060) 0000000020000000-0000000023ffffff o:0040 a:0007 p:100 c:00000000 n:32 0080) 000000002010e108-00000000206c223f o:0000 a:0005 p:100 c:00000000 n:60 00a0) 0000000020100000-000000002010e107 o:0000 a:0007 p:100 c:00000000 n:68 00c0) 000000002010e108-00000000206c223f o:0000 a:0007 p:100 c:00000000 n:76 00e0) 0000000020000000-0000000020007fff o:0020 a:0007 p:100 c:00000000 n:84 0100) 0000000020010834-00000000200fffff o:0020 a:0007 p:100 c:00000000 n:84 0120) 00000000206c2240-0000000023ffffff o:0020 a:0007 p:100 c:00000000 n:84 Section:hwinfo offset:0x000002d8 size:0x00000048 0) size:3 tag:3 isize:3, iname:0, owner:65535, kids:1 12) size:3 tag:17 isize:3, iname:9, owner:0, kids:1 24) size:3 tag:3 isize:3, iname:37, owner:12, kids:1 36) size:4 tag:46 isize:4, iname:41, owner:24, kids:0 00 00 00 00 Section:typed_strings offset:0x00000258 size:0x00000020 off:0 type:5 string:'UNKNOWN' off:12 type:2 string:'localhost' Section:strings offset:0x00000278 size:0x00000060 [0]'hw' [3]'Group' [9]'unknown' [17]'Bus' [21]'memory' [28]'ram' [32]'1to1' [37]'rtc' [41]'NONE' [46]'Device' [53]'arm926' [60]'imagefs' [68]'startup' [76]'bootram' [84]'sysram' Section:intrinfo offset:0x00000460 size:0x00000040 0) vector_base:00000000, #vectors:32, cascade_vector:7fffffff cpu_intr_base:00000000, cpu_intr_stride:0, flags:0000 id => flags:8000, size:002c, rtn:fc4045a0 eoi => flags:9000, size:0028, rtn:fc4045cc mask:fc4045f4, unmask:fc404618, config:00000000 Section:smp offset:0x000004e0 size:0x00000000 Section:pminfo offset:0x000004e0 size:0x00000000 Section:mdriver offset:0x000004e0 size:0x00000000 Section:boxinfo offset:0x000001c8 size:0x00000028 hw_flags:00000000 Section:cpu offset:0x00000128 size:0x00000020 page_flush:fc404564 page_flush_deferred:fc40459c upte_ro:00000aae upte_rw:00000ffe kpte_ro:0000000e kpte_rw:0000055e mask_nc:0000000c mmu_cr1:00051078 set:0000317f clr:00000000 -> 0005317f System page at phys:20010000 user:fc404000 kern:fc404000 Starting next program at vfe03d838 cpu_startnext: cpu0 -> fe03d838 Welcome to QNX Neutrino 6.4 on the Atmel AT91SAM9260 Board Starting DBGU driver... Starting Serial USART 1 driver ... Starting SPI driver... Starting NAND driver... # You can test the OS simply by executing any shell builtin command or any command residing within the OS image (e.g. ls). Step 3B: Reprogram the IPL.#In case if Board is new or IPL gets corrupted, We can reprogram IPL using SAM-BA application.
Step 3C: Download the combined IPL and IFS onto Data-Flash#
RomBOOT > QNX Neutrino Initial Program Loader for ATMEL AT91SAM9260-EK Commands: Press 'D' for serial download, using the 'sendnto' utility Press 'F' to Boot an OS image from SPI/SERIAL flash ATMEL AT45DB642D/AT45DCB008D SPI Flash detected. QNX IFS image detected on page: 00000004 Offset: 000003A0 Size: 005C2240 ######################################################Done found image, calling image setup... image_setup OK, calling image start... PIO init : DBGU, USART, NAND, CPU0: Dcache: 256x32 WB CPU0: Icache: 256x32 CPU0: 41069265: arm926 rev 5 100MHz elf_map: 1M va=fe000000 pa=20100000 sz=00100000 elf_map: 1M va=fe000000 pa=20100000 sz=00100000 Header size=0x0000009c, Total Size=0x000004e0, #Cpu=1, Type=4 Section:system_private offset:0x000001f0 size:0x00000068 syspage ptr user:fc404000 kernel:fc404000 cpupage ptr user:fc4047e0 kernel:fc4047e0 spacing:84 kdebug info:00000000 callback:00000000 boot pgms: idx=0 0) base paddr:20110000 start addr:fe03d838 ramsize:00000000 pagesize:00001000 Section:qtime offset:0x00000148 size:0x00000060 boot:00000000 CPS:00000000002faf08 rate/scale:320000000/-15 intr:1 Section:callout offset:0x000000a0 size:0x00000048 reboot:fc404658 power:fc404678 timer_load:fc40468c reload:fc4046b4 value:fc4046e0 0) display:fc404700 poll:fc404724 break:fc404748 1) display:00000000 poll:00000000 break:00000000 Section:cpuinfo offset:0x000001a8 size:0x00000020 0) cpu:41069265 flags:40000000 speed:00000064 cache i/d:1/0 name:53 Section:cacheattr offset:0x000004a0 size:0x00000040 0) flags:32 size:0020 #lines:0100 control:fc4044e0 next:255 1) flags:11 size:0020 #lines:0100 control:fc404534 next:255 Section:meminfo offset:0x000004e0 size:0x00000000 Section:asinfo offset:0x00000320 size:0x00000140 0000) 0000000000000000-00000000ffffffff o:ffff a:0010 p:100 c:00000000 n:21 0020) 0000000020000000-0000000023ffffff o:0000 a:0017 p:100 c:00000000 n:28 0040) 0000000000000000-00000000ffffffff o:ffff a:0010 p:100 c:00000000 n:21 0060) 0000000020000000-0000000023ffffff o:0040 a:0007 p:100 c:00000000 n:32 0080) 000000002010e108-00000000206c223f o:0000 a:0005 p:100 c:00000000 n:60 00a0) 0000000020100000-000000002010e107 o:0000 a:0007 p:100 c:00000000 n:68 00c0) 000000002010e108-00000000206c223f o:0000 a:0007 p:100 c:00000000 n:76 00e0) 0000000020000000-0000000020007fff o:0020 a:0007 p:100 c:00000000 n:84 0100) 0000000020010834-00000000200fffff o:0020 a:0007 p:100 c:00000000 n:84 0120) 00000000206c2240-0000000023ffffff o:0020 a:0007 p:100 c:00000000 n:84 Section:hwinfo offset:0x000002d8 size:0x00000048 0) size:3 tag:3 isize:3, iname:0, owner:65535, kids:1 12) size:3 tag:17 isize:3, iname:9, owner:0, kids:1 24) size:3 tag:3 isize:3, iname:37, owner:12, kids:1 36) size:4 tag:46 isize:4, iname:41, owner:24, kids:0 00 00 00 00 Section:typed_strings offset:0x00000258 size:0x00000020 off:0 type:5 string:'UNKNOWN' off:12 type:2 string:'localhost' Section:strings offset:0x00000278 size:0x00000060 [0]'hw' [3]'Group' [9]'unknown' [17]'Bus' [21]'memory' [28]'ram' [32]'1to1' [37]'rtc' [41]'NONE' [46]'Device' [53]'arm926' [60]'imagefs' [68]'startup' [76]'bootram' [84]'sysram' Section:intrinfo offset:0x00000460 size:0x00000040 0) vector_base:00000000, #vectors:32, cascade_vector:7fffffff cpu_intr_base:00000000, cpu_intr_stride:0, flags:0000 id => flags:8000, size:002c, rtn:fc4045a0 eoi => flags:9000, size:0028, rtn:fc4045cc mask:fc4045f4, unmask:fc404618, config:00000000 Section:smp offset:0x000004e0 size:0x00000000 Section:pminfo offset:0x000004e0 size:0x00000000 Section:mdriver offset:0x000004e0 size:0x00000000 Section:boxinfo offset:0x000001c8 size:0x00000028 hw_flags:00000000 Section:cpu offset:0x00000128 size:0x00000020 page_flush:fc404564 page_flush_deferred:fc40459c upte_ro:00000aae upte_rw:00000ffe kpte_ro:0000000e kpte_rw:0000055e mask_nc:0000000c mmu_cr1:00051078 set:0000317f clr:00000000 -> 0005317f System page at phys:20010000 user:fc404000 kern:fc404000 Starting next program at vfe03d838 cpu_startnext: cpu0 -> fe03d838 Welcome to QNX Neutrino 6.4 on the Atmel AT91SAM9260 Board Starting DBGU driver... Starting Serial USART 1 driver ... Starting SPI driver... Starting NAND driver... # You can test the OS simply by executing any shell builtin command or any command residing within the OS image (e.g. ls). Summary of driver commands#The driver command lines below are specific to the Atmel AT91SAM9260 board. See the online docs for each driver for additional command-line options and other details. Note: Some of the following drivers are commented out in the default buildfile. To use the drivers in the target hardware, you'll need to uncomment them in your buildfile, rebuild the image, and load the image into the board. Startup:#Command:startup-at91sam9260 -vvvvvvv Serial:#Command:devc-serusart -F -S -u2 -b115200 -c50000000 0xfffb0000^2,6Required binaries:
devc-serdebug -e -F -S -b115200 -c50000000 0xfffff200,1Required binaries:
SPI:#Command:spi-master -u0 -d at91sam9xx base=0xFFFC8000,irq=12,clock=50000000 spi-master -u1 -d at91sam9xx base=0xFFFCC000,irq=13,clock=50000000Required binaries:
Network:#Command:io-pkt-v4 -dat91sam9xx mac=662200021615 -ptcpipRequired binaries:
SD:#Command:devb-mmcsd-at91sam9xxRequired binaries:
ETFS NAND flash#Command:fs-etfs-at91sam9xx -D addr=0x40000000,board_id=at91sam9260-ek -m /fs/etfsRequired binaries:
Note: For more information about these commands, see the Neutrino Utilities Reference.
Known Issues for This BSP#
Versions | Associations | Attachments (9) | Back Links | |||||||
Page Name | Added By | Added On |
NtotrunkAtmelAt91sam9260EkEvbTrunkReleasenotes | kanhaiya lal | 08/05/2009 5:04 AM EDT |
Nto640AtmelAt91sam9260EKEVBTrunkReleasenotes | Johnny Lin(deleted) | 08/05/2009 5:42 AM EDT |
AT91SAM9260EKEvaluationBoard | David Green | 08/05/2009 5:00 AM EDT |
