| wiki2127: Trinity2M7Build (Version 1) |
What's New#The latest M7 head branch build from March 15, 2008 has the following features:
Installation Instructions#NOTE Since this is a destructive procedure, we recommend that you create a backup of the affected files. Here is an example of how to backup the files you are going to overwrite when installing the M7 build on a QNX Momentics 632 host system.#
1. Create the directory /tmp/shiplist
#mkdir /tmp/shiplist
2. Untar the package into your /tmp/shiplist directory (Assumes you've already downloaded the package detailed in the next section).
#cd /tmp/shiplist
#tar -zxvof archive_path/ntocore_nto.tar.gz .
3. Create a shiplist.txt file
#find > /tmp/shiplist.txt
4. Create a backup tarball from the shiplist.txt using your base directory(base_dir) as the root directory.
#cd /usr/qnx632 (assuming this is your base_dir, see below if you are unsure)
#pax -w < /tmp/shiplist.txt > /tmp/632-backup.tar
NOTE: Since some of the files in this shiplist won't already be on your system, there will be errors when the tarball is created.
Take note of these because if you want to remove the M7 build, then you will have to manually remove these when restoring the 632-backup.tar file.
When Restoring you will need to cd into the base_dir and run the command:
#tar -xvof /tmp/632-backup.tar
Then remove the files noted above.
Installing the package#
$ qconfig
QNX Installations
Installation Name: QNX Momentics Development Suite 6.3.2
Version: 6.3.2
Base Directory: /usr/qnx632/
QNX_HOST: /usr/qnx632/host/qnx6/x86/
QNX_TARGET: /usr/qnx632/target/qnx6/
The base directory in this example is /usr/qnx632/, but it could be different on your machine, depending on your host and where you installed QNX Momentics.
4. Extract the archive you downloaded into the base directory:
Command-line based
Windows hosts:
1. Open a command prompt (cmd.exe) and switch to the drive indicated in the base directory that you found in step 2 (e.g. C:).
2. Copy the archive to your base directory, replacing base_dir with the path you found in step 2:
copy drive:\ntocore_win32.tar.gz base_dir
3. Use the following commands to extract the archive contents. Don't specify the drive letter in the archive path:
cd base_dir
tar -zxvf ntocore_win32.tar.gz
Neutrino and Linux hosts:
Open a command shell and use the following commands (replacing base_dir with the path found in step 2, and archive_path with the
full path to the downloaded archive):
cd base_dir
tar -x -v -f archive_path/ntocore_nto.tar.gz NOTE replace _nto with _linux on Linux hosts
If you are using a QNX Neutrino host you may want to install the runtime components and run Trinity2. To do this you will have to populate
your host's runtime with the M7 build components, rebuild your image and reboot your board.
To install the runtime update:
cd $QNX_TARGET/x86
cp -fRp . /
To rebuild your boot image using the runtime update:
1. Backup your build file
cp /.boot /.altboot
2. Then rebuild your boot image so that it will now include the updated shared objects and procnto. In this example, we are assuming that you are
using /boot/build/qnxbasedma.build
cd /boot/build
mkifs -vv qnxbasedma.build /.boot
3. Reboot your machine and voila, you are now running Trinity2!
