wiki1424: Project Home Page |
Quick Links QNX Community QEMU™ Project overview#QEMU is a generic and open source machine emulator and virtualizer. When used as a machine emulator, QEMU can run OSes and programs made for one machine (e.g. an ARM board) on a different machine (e.g. your own PC). By using dynamic translation, it achieves very good performances. QEMU is based on SDL (Simple DirectMedia Layer - http://www.libsdl.org/) that provides graphical output. In QNX you can use QEMU with SDL Photon or XFree86/X.Org build. System requirements#
Sound card (to listen sounds from guest machine) and CD/DVD drive to install OSes from optical. Resources#To download latest build of QEMU you should go to Project Downloads page. You can also get an old build at http://community.qnx.com/sf/wiki/do/viewAttachment/projects.qemu/wiki/NeutrinoAsHostForQEMU/qemu-0.9.0-qnx.tar.gz. QEMU is based on SDL library but you don't need it because in svn builds SDL 1.2.13 is linked statically with QEMU. Links#
QEMU is a trademark of Fabrice Bellard. All rights reserved. |
Versions | Associations | Attachments | Back Links | |||||||
