wiki1254: Bspdown3 (Version 4)
Centrality Atlas II EVB Board Support Package#
This BSP supports the Centrality Atlas II EVB board.
Releases#
TRUNK#
Date Version Prerequisites Installation Notes Release Notes License(s) Support Provider Download Source Tag
Coming Soon! trunk QNX Momentics 6.4 6.4 Generic Notes here Apache II Experimental QNX Coming Soon! Coming Soon!
QNX Neutrino 6.4#
Coming Soon! 1.0.0 QNX Momentics 6.4 6.4 Generic Notes here Apache II Experimental QNX Coming Soon! Coming Soon!
QNX Neutrino 6.3.2#
2006-10-27 1.0.0 QNX Momentics 6.3.x SP2 or later + AGTDK 6.3.2 Generic Notes here MEULA Experimental QNX QNX Download Center none
Features#
Feature Planned Availability Format Notes
Audio Completed SRC .
Ethernet Completed SRC .
Graphic Completed SRC .
IPL Completed SRC .
I2C Completed SRC .
NAND Completed SRC .
Serial Completed SRC .
Startup Completed SRC .
SD Completed BIN .
USP Completed SRC .
USB Host Completed BIN .
Some of these drivers are commented out in the default buildfile. To use the drivers in the target hardware, you'll need to uncomment them in your buildfile, rebuild the image, and load the image into the board.
TRUNK Change History#
Trunk#
  • Created from QNX Neutrino 6.3.2 Centrality Atlas II BSP version 1.0.0
  • Built using the latest 6.4 toolchain
6.4 Change History#
1.0.0#
6.3.2 Change History#
1.0.0#
  • Initial release under MEULA
  • Includes:
    • IPL
    • Graphics
    • I2C
    • Serial
    • Startup
    • NAND
    • Ethernet
    • audio
    • USP
    • USB Host
    • SD
Versions Associations Attachments Back Links
