QNX Operating System
OSDeveloperInformation
View Wiki Page
Search Wiki Pages
wiki1042: OSDeveloperInformation (Version 42)
Quick Links
OS Wiki
Source Guide
Roadmap
Developer Info
Tech
Forums
Note: This project does NOT include
source access
This page should have links to all pages, not about specific code, that helps people develop. If you're looking for code design or tech information, try the
OS Tech
page.
Getting started
The Getting Started Guide
Get The OS Source
Build The OS Source
Using What You Built
Understanding the Source Tree
A developer's
getting started guide
: source tree layout | picking a dev env | build targets | staging areas
Contributing to the OS
Report bugs ... Request features ... Contribute new code
Debugging
Debugging the Kernel
Kernel Debugging and the IDE
VMWare and Kernel Debugging
QEMU and Neutrino
QEMU as an OMAP3530 Beagleboard Target
Debug Malloc
Common Causes of Kernel Crashes
Build
Build The OS Source
Understanding the Neutrino Build Process
Regular test builds:
Tinderbox Contents
Using the
Momentics IDE to build the Kernel
Tricky Dev Topics
GCC Extended Inline Assembly Constraints
User Documentation:
System Architecture Guide
User's Guide
Programmer's Guide
Building Embedded Systems
Utilities Reference
Library Reference
Can't Find It?
Post to the
OSDev
forum. Or try the
OS Tech
page.
View HTML
View PDF
Hide Details
Versions
Associations
Back Links
Version
From To
Version Comment
Created By
Version 42
Remove outdated coding guidelines
Steve Bergwerff(deleted)
- 04/21/2015
Version 41
- 08/12/2014
Version 40
- 08/12/2014
Version 39
- 08/08/2014
Version 38
Colin Burgess(deleted)
- 10/11/2011
Version 37
Added link for new GCC asm constraints page.
Neil Schellenberger(deleted)
- 06/12/2009
Version 36
Brian K Hlady(deleted)
- 11/07/2007
Version 35
Attilla Danko
- 10/25/2007
Version 34
Thomas Fletcher
- 09/27/2007
Version 33
Thomas Fletcher
- 09/11/2007
Version 32
minor reformat
Attilla Danko(deleted)
- 09/10/2007
Version 31
fix nav bar format
- 09/10/2007
Version 30
make how-to-port point to svn
- 09/10/2007
Version 29
add link to forum
- 09/10/2007
Version 28
- 09/10/2007
Version 27
- 09/10/2007
Version 26
- 09/10/2007
Version 25
- 09/10/2007
Version 24
- 09/10/2007
Version 23
- 09/10/2007
Version 22
- 09/10/2007
Version 21
- 09/10/2007
Version 20
- 09/10/2007
Version 19
- 09/07/2007
Version 18
- 09/06/2007
Version 17
- 09/06/2007
Version 16
- 09/06/2007
Version 15
- 09/05/2007
Version 14
remove duplicate link
- 09/04/2007
Version 13
replace full urls (causing this silly wiki engine to popopen new browsers) with wiki links
- 09/04/2007
Version 12
- 08/31/2007
Version 11
- 08/31/2007
Version 10
- 08/31/2007
Version 9
- 08/31/2007
Version 8
- 08/31/2007
Version 7
- 08/28/2007
Version 6
- 08/28/2007
Version 5
Thomas Fletcher
- 08/28/2007
Version 4
Thomas Fletcher
- 08/26/2007
Version 3
Thomas Fletcher
- 08/26/2007
Version 2
Thomas Fletcher
- 07/23/2007
Version 1
Thomas Fletcher
- 07/23/2007
Compare
