slinger will not run SSI or CGI in read-only OS filesystem image
05/29/2013 3:13 PM
post101836
Attached is my build and boot script for Nitrogren6X. The issue is SSI and CGI does not work on my target under slinger
, although when I tested it on the x86 QNX VM it worked fine. For example, something like:
Date and Time (Local): <!--#echo var="DATE_LOCAL" -->
shows up like
on my Nitrogen6X system. I have the appropriate libraries built into the image (io-pkt*.so and libsocket.so) so I'm not
sure if I'm missing something else. Also, I'm not sure if slinger SSI and CGI can work under a read-only monolithic OS
file system image. Does it need a writeable filesystem?
