RE: Building Webkit on ubuntu 9.04
08/31/2010 3:43 PM
post65308
thanks
Sent: Tuesday, August 31, 2010 12:33 PM
To: general-web_browsers
Subject: RE: Building Webkit on ubuntu 9.04
You should be fine with newer versions of Ubuntu. I am using 10.04 LTS.
From: Darrin Garrett [mailto:community-noreply@qnx.com]
Sent: Tuesday, August 31, 2010 1:58 PM
Subject: Building Webkit on ubuntu 9.04
The latest readme file specifies that you can build webkit on ubuntu
9.04.
Has anyone tried with success to build webkit on a newer version of
ubuntu?
the opt-crank will install on ubuntu 10.04 with the addition of
ia32-libs
General
http://community.qnx.com/sf/go/post65269
General
http://community.qnx.com/sf/go/post65296
The information contained in this message, including attachments, may contain privileged and/or confidential information
that is intended to be delivered only to the person(s) identified above. If you are not the intended recipient(s), or
the person responsible for delivering this message to the intended recipient(s), Airbiquity Inc. requests that you
immediately notify the sender and asks that you do not read the message or its attachments and that you delete them
without copying or sending them to anyone else. Any review, reliance or distribution by others not intended as
recipients or forwarding without express permission is strictly prohibited. Replies to this message may be received by
other Airbiquity personnel in addition to the intended recipient(s).
