10/11/2022 2:14 AM
post121952
We installed the QT through QNX software center (Fig QT_QNX).
We are using SDP 7.0 and QNX Momentics IDE (Version: 7.0.4.v201905030143) in our design. During compilation, we are
getting error in qmake.(fig 1)
We understand that it was because of some issue in setting the Environment variable of QT PATH (\qt\Qt5.6.2\win64\x86_64
\target\x86\bin) in Momentics IDE. We are using a ‘.bat’ file to set the required PATH for the project. And from the
.bat file, we open the Momentics IDE through the command “start %QNX_INSTALL%..\..\..\QNX\"QNX_Momentics_IDE"\qde.exe
-data %XXX_ROOT%\.. -vmargs eclipse.p2.data.area=%QNX_INSTALL%..\..\..\QNX\"QNX_Momentics_IDE"\p2””.
In the “Environment tab” under project settings, we found that the toolchain path is prepended before the path we
created with .bat file. We manually modified the PATH variable in IDE, by declaring the of QT PATH (\qt\Qt5.6.2\win64\
x86_64\target\x86\bin) before the toolchain path. And the compilation was successful. (fig 2)
Could you please let us know, how we can solve the issue? Also, is there any method to prepend the QT path variable
before toolchain path from the .bat file?
Manoj
