Forum Topic - Qt 5.2.0 dev env for linux with target binaries/plugins dependent in libstdc++ and not libstdcpp(-ne): (3 Items)
I am using the released binaries for Qt. 5.2.0 on Linux and notice that they are dependent on the libstdcpp library.
The project I am working on consistently depends on the libstdc++ (GNU C++) library.
I've noticed that the Qt libraries depend on the libstdcpp (Dinkum C++) library.
Our Qt application is compiled/linked with the GNU C++ library, but the Dinkum C++ library is pulled in from the
applications Qt library dependencies. This is causing run-time failures as two C++ libraries are loaded by the
application.
Do you have a Qt 5.2.0 development environment compiled/linked against the GNU C++ library?
I do not have the ability to convert the rest of the project to the Dinkum C++ library.
Thank you,
Steven Zajac
Re: Qt 5.2.0 dev env for linux with target binaries/plugins dependent in libstdc++ and not libstdcpp(-ne)
Hello Knowledgeable Forum Browsers and Forum Moderators,
   I was able to build Qt 5.2.0 from the supplied package using the instructions here:
http://community.qnx.com/sf/wiki/do/viewPage/projects.qt/wiki/Qt5.2.0BuildInstructionsForQNXSDKForAppsAndMedia1.0
If you are unable to provide Qt binaries that do not depend on the libcpp-ne and/or libcpp libraries, can you tell me
how to configure the Qt make to use ONLY the GNU C++ (libstdc++) library?
I've rebuilt Qt numerous times. These have mostly the same configuration as described in the link above (building for
Windows). I've added the -no-c++11 flag and have attempted to remove the -platform [arg] flag altogether.
I've also changed some of the make configuration files (/qtbase/mkspecs/common/*.conf) to try and force it to use the
GNU flavor compiler/linker.
After building Qt, I see that libcpp-ne is included in at least the Qt5Core library.
I fear I am spinning my wheels and overlooking what could be a simple solution. Can you please point me in the right
direction?
Steven Zajac
If anyone else is trying to do this, here is our solution:
Follow the steps as in the Qt 5.2.0 build instructions here: http://community.qnx.com/sf/wiki/do/viewPage/projects.qt/
We installed on Windows.
After running 'configure', and before running 'make', go to your PATH/qtbase/mkspecs/common folder and update the
following files to use explicit compiler/linker commands (to compile/link with GNU tools instead of Dinkum), and remove
the '-lang-c++' flag wherever found:
   g++-base.conf, qcc-base.conf, qcc-base-qnx.conf, qcc-base-qnx-armv7le.conf
Add the '-lstdc++' flag to QMAKE_LIBS in qcc-base-qnx.conf.
In your filesystem, rename the libcpp-ne.so* files found in C:\QNX660\*. That way, Qt won't be able to link against it
(because it won't find it).
Now make / make install and hope for the best.
