Forum Topic - QtCreator with CMake: No generator found:
I am trying to setup Qt Creator to build a Qt application for a QNX device with CMake. I have a Kit defined for my
target device which works fine for usage within a qmake project. However, for a cmake project when I select to run CMake
 the combobox for choosing a generator remains empty. Does anybody know how I can configure QtCreator to use a correct
generator for QNX?
Thanks.
Re: QtCreator with CMake: No generator found
Did you get cmake working on the command line? Is this issue about QtCreator only? Just to pre-warn you :-) cmake can be
 made integrated/used on/with Qt on QNX and in QtCreator with Qt on QNX, but this is not something which works out of
the box.
Yes, I managed to get it working in the command line and also in qt creator if you choose the desktop as a target. Thus
I can manually copy my executable to the target and it works. It really seems to be only a problem with the QtCreator
that it prohibits selecting a generator when compiling and deploying to a QNX device. Any ideas?
That's actually a bug :) So far Qt Creator only provides generators for kits with a "desktop" or "gerenic remote linux"
device types and we need to extend this to include QNX devices as well (the QNX plugin in Qt Creator was mainly
supporting qmake based project since using CMake was not a common use case). We'll upsteam a patch for this asap. Thanks
 for the feedback!
P.S:  If you encounter any further issues while developing for QNX in Qt Creator, please file a bug report in https://
bugreports.qt-project.org/browse/QTCREATORBUG/component/19925 for a better view on the progress. Thanks!
Just a quick update: the fix is now submitted and the issue should be fixed in the comming 3.1.1 patch version of Qt
Creator. You can also get a recent snaphot build from: https://download.qt-project.org/snapshots/qtcreator/3.1.1/ that
contains the fix.
Please note that the CMake plugin in Qt Creator is not fully functional when deploying and running on remot targets.
I've updated the wiki page: http://qt-project.org/wiki/Setting-up-Qt-Creator-for-QNX to add instructions when using
CMake build system.
