Forum Topic - How to run QNX terminal in qws?:
Hello! I have a problem :(
I don’t know how to run QNX terminal in qws ( when Qt-application is running).
What are the ways to solve this problem?
Re: How to run QNX terminal in qws?
I assume you want to run "shell" while Qt is running?
1. Unless running on x86, you can add '&' to the Qt command line and have use of the shell
2. You can enable telnet login
3. You can enable a login on another serial port (tinit)
