Re: 3D QT Support for QNX
05/21/2014 4:39 PM
post110440
Hi Seyfettin,
You can definitely port a 3D application to QNX. If you are talking specifically about a Qt application that uses the
QtOpenGL module you should just need to build your application using the Qt packages posted on in the File Releases
section and your application will be able to run on QNX OS 6.6. Can you post more specifics about the application you
would like to port?
- Tim -
