09/17/2012 3:40 AM
post95596
I'm using ubuntu 11.10. I complied qt hello world application for omap3530 beagle board.
I'm using qt_every_where and qnx_qnx.
There is an error in my Target Setup step. I complied qt hellowrold project. You can look image5.png for complie steps
also if you wanna look qthelloworld application source you can look image12.png
I wanna add qt library for beagle qnx .ifs image but ı'm only added dependencies libarry. I don't know how the process
would be to add.
ı have read this comments.
Qt libraries:
$ARCH/usr/lib/libQt*.so* (libQt*.so.4 on targets with no symlink support) /I could not do
the process of adding
$ARCH/usr/lib/qt4/plugins/
/I could not do the process of adding
$ARCH/usr/lib/qt4/imports/
Dependencies:
$ARCH/lib/libc.so.3 /i added this library with momentics ide
$ARCH/lib/libcpp.so.4 /i added this library with momentics ide
$ARCH/lib/libgf.so.1 /i added this library with momentics ide
$ARCH/lib/libm.so.2 /i added this library with momentics ide
$ARCH/lib/libsocket.so.2 /i added this library with momentics ide
$ARCH/lib/libsocket.so.3 /i added this library with momentics ide
$ARCH/lib/libstdc++.so.6 /i added this library with momentics ide
$ARCH/usr/lib/libz.so.2 /i added this library with momentics ide
Data files:
usr/share/qt4/translations/ /I could not do the process of adding
usr/photon/font_repository/ /I could not do the process of adding
I need to adding qt libraries for . ifs image.
Thanks for Helps
