Re: Program to Cause a Kernel Panic as an Unprivilieged User
09/25/2009 3:35 PM
post38816
Here's my command line that I used just now to compile and run the program:
# cc -o panic panic.c
/usr/watcom/10.6/bin/wcc386 -zq -ms -4r -i=/usr/watcom/10.6/usr/include -i=/usr/include panic.c
/usr/watcom/10.6/bin/wlink op quiet form qnx flat na panic op priv=3 op c libp /usr/watcom/10.6/usr/lib:/usr/lib:/cti/
lib:/usr/local/lib:/usr/local/ssl/lib f panic.o op offset=40k op st=32k
# ./panic
At this point, I get a stack and register dump to the console, manually typed out below:
Version: 424.G Aug 25 1997 Technical Support: +1 (613) 591-0941
Proc fault 1, ldt 100 sys/Proc32; fault d+0
cs:eip=5:7714 ss:esp=d:f7c0f3c efl=12246 ds=d es=8 fs=0 gs=0
eax/10fbeffc ebx/ffffffff ecx/1 edx/0 esi/10fbeffc edi/35ea5 ebp/f7c0f40
Stack (d:f7c0f3c)
10fbeffc 0f7c0f58 ffffffff 00000011 00000001 00007b58 0f7c0f84 0f7c0f84
000029b6 ffffffff 0001a346 0001cbac a800000f 35e98000 0000e000 00000001
00000011 00000000 0f7c0fb0 000029b6 0000339c 00011483 00000001 0000000d
000033ac 0001cbac 00000001 00000001 00000000 0f7c0fec 000052fd 0001cbac
Process Entry (addr 18c5c)
00000000 00000001 00000000 00000001 00000000 00000000 30020207 00001e1e
000051f0 0100000d 00018d14 ffffffff 00000000 00000000 00000000 00000000
00000000 00000000 00000000 00000501 000d000d 00006884 00000000 00000005
00000018 00000000 000001a0 0000d9e0 00000000 00000000 0001c1f4 00000000
00000000 00000000 00000000 ffff0001 00000000 00000000 00000000
Here is the version information for the test box in this example:
# uname -a
QNX 5 G 424 PCI 32
# sin ver
PROGRAM NAME VERSION DATE
sys/Proc32 Proc 4.24G Aug 25 1997
sys/Proc32 Slib16 4.23G Oct 04 1996
sys/Slib32 Slib32 4.24A Feb 04 1997
/bin/Fsys Fsys32 4.24K Aug 20 1997
/bin/Fsys Floppy 4.24B Aug 19 1997
/bin/Fsys.eide eide 4.24F Jul 17 1997
//5/bin/Dev32 Dev32 4.23G Oct 04 1996
//5/bin/Dev32.ansi Dev32.ansi 4.23H Nov 21 1996
//5/bin/Dev32.ser Dev32.ser 4.23I Jun 27 1997
//5/bin/Dev32.pty Dev32.pty 4.23G Oct 04 1996
//5/bin/Pipe Pipe 4.23A Feb 26 1996
//5/bin/Net Net 4.24B Jul 31 1997
//5/bin/Net.ct100tx Net.ct100tx 4.25F Aug 20 2001
//5/*/5.0/usr/ucb/Tcpip Tcpip 5.00A Jan 26 2001
# sin
SID PID PROGRAM PRI STATE BLK CODE DATA
-- -- Microkernel --- ----- --- 11696 0
0 1 sys/Proc32 30f READY --- 114k 1699k
0 2 sys/Slib32 10r RECV 0 53k 4096
0 4 /bin/Fsys 29r RECV 0 77k 146M
0 5 /bin/Fsys.eide 22r RECV 0 57k 110k
0 8 idle 0r READY --- 0 65k
0 16 //5/bin/Dev32 24f RECV 0 32k 143k
0 19 //5/bin/Dev32.ansi 20r RECV 0 40k 122k
0 21 //5/bin/Dev32.ser 20r RECV 0 16k 24k
0 22 //5/bin/Dev32.pty 20r RECV 0 12k 57k
0 23 //5/bin/Dev32.pty 20r RECV 0 12k 32k
0 28 //5/bin/Fsys.floppy 10o RECV 0 20k 40k
0 29 //5/bin/Pipe 10r RECV 0 16k 53k
0 33 //5/bin/Net 23r RECV 0 32k 106k
0 37 //5/bin/Net.ct100tx 20r RECV 0 61k 135k
0 41 //5/bin/nameloc 20o RECV 0 6144 20k
0 42 //5/bin/nameloc 20o REPLY 0 6144 16k
0 93 //5/*/5.0/usr/ucb/Tcpip 10r RECV 0 151k 471k
0 100 //5/*/5.0/usr/ucb/inetd 10o RECV 102 40k 24k
0 104 //5/bin/tinit 10o WAIT -1 16k 28k
0 105 //5/bin/dumper 10o RECV 0 16k 20k
0 107 //5/*/usr/bin/syslogd 10o RECV 0 36k 32k
0 109...
09/25/2009 5:06 PM
post38827
I apologize. After re-testing on all my development machines, it turns out that I was mistaken about the panic occurring
on my 4.25 test box.
This box does not panic:
# sin ver
/boot/sys/Proc32 Proc 4.25O Aug 19 2002
/boot/sys/Proc32 Slib16 4.23G Oct 04 1996
/boot/sys/Slib32 Slib32 4.24B Aug 12 1997
/bin/Fsys Fsys32 4.24Y Apr 23 2002
/bin/Fsys.atapi atapi 4.25G Aug 08 2007
//6/bin/Dev32 Dev32 4.23G Oct 04 1996
//6/bin/Pipe Pipe 4.23A Feb 26 1996
//6/bin/Dev32.ser Dev.ser 4.25A Feb 14 2003
//6/bin/Dev32.ansi Dev32.ansi 4.23H Nov 21 1996
//6/bin/Dev32.par Dev32.par 4.25A Jan 08 2001
//6/bin/Dev32.pty Dev32.pty 4.23G Oct 04 1996
//6/bin/Net Net 4.25E Apr 24 2002
//6/bin/Net.befe124 Net.befe124 4.25C Nov 27 2004
//6/*/5.0/usr/ucb/Tcpip Tcpip 5.00A Jan 26 2001
This box (different from the one in my previous post) does panic:
# sin ver
//10/bin/Dev16 Dev16 4.23G Oct 04 1996
//10/bin/Dev16.ansi Dev16.ansi 4.23H Nov 21 1996
//10/bin/Dev16.ser Dev16.ser 4.23I Jun 27 1997
//10/bin/Dev16.par Dev16.par 4.23G Oct 04 1996
//10/bin/Dev16.pty Dev16.pty 4.23G Oct 04 1996
//10/bin/Pipe Pipe 4.23A Feb 26 1996
//10/bin/Net Net 4.24B Jul 31 1997
//10/bin/Net.ct100tx Net.ct100tx 4.23C May 02 1997
//10/*/usr/ucb/Socket Socket 4.25G Dec 08 1998
//10/bin/cron cron 4.23B Dec 18 1996
