Forum Topic - how to read the actual photon region:
We need to know the best way to read in a photon region to an image or char array. So we have access to the pixel color
data. We are using QNX4.25.
We want to grab the screen from a process, which will not draw to photon and should just read back what another process
have drawn.
We did not find a suitable function to accomplish that, we just found out that QNX6 has the PgReadScreen function to do
this.
Re: how to read the actual photon region
Hi Sebastian,
Unfortunately, PgReadScreen() is not implemented in QNX 4. So you have two option:
1. Use snapshot utility.
2. In case of using Pg.flat* driver you can determine physical framebuffer address, map it in your app and read from it
according to current graphics mode.
> array. So we have access to the pixel color data. We are using QNX4.25.
> should just read back what another process have drawn.
>  QNX6 has the PgReadScreen function to do this.
Hi Oleg,
thank you for your valuable suggestions.
These options have also come to my mind.
Best regards,
Sebastian
> Hi Sebastian,
> option:
> address, map it in your app and read from it according to current graphics
> mode.
> Respectfully,
> Oleg
