Forum Topic - Siemens IPC347E Graphics driver:
I've loaded this PC with the latest QNX 4.25 product suite and now I'm having problems with the video driver, I've tried
 quite a number and none of them work as required.
I've attached a show_pci dump for help.
Any ideas?
Thanks and regards,
Pete
Attachment: Text show_pci.txt 30.64 KB
Re: Siemens IPC347E Graphics driver
I've found a driver that works ... Pg.flatdc32.
Pete
Hi Pete,
Pg.flat* is a driver family that provides support for the most graphics controllers. Modern graphics controllers often
don't support 8-, 15- and 16-bit color modes, so Pg.flatdc32 is the best choice in that case.
17 янв. 2018 г., в 13:47:34, Pete Mackereth <community-noreply@qnx.com> написал:
> Hello,
> Thanks,
> Pete
> http://community.qnx.com/sf/go/post118396
RE: Siemens IPC347E Graphics driver
Thanks Oleg.
From: Олег Большаков [mailto:community-noreply@qnx.com]
Sent: 17 January 2018 11:50
To: general-qnx4@community.qnx.com
Subject: Re: Siemens IPC347E Graphics driver
Hi Pete,
> Hello,
> Thanks,
> Pete
General
http://community.qnx.com/sf/go/post118397
Hello Pet,
This problem may occur due to incorrect installation of the video driver. Try to find and delete the latest driver
version that you installed and restart your computer after that. Download any windows 10 registry cleaner (here is the
list of the best cleaners https://thinkmobiles.com/blog/best-registry-cleaner-tools/) and clean your registry. Then
download the program for automatic driver updates and it will do all the work for you and select the right driver for
your computer. After installing all the drivers, restart your computer again and this problem should disappear.
Good luck, sincerely Mark.
