Forum Topic - memory leak snmp: (5 Items)
memory leak snmp
Hello QNX admins,
I am using snmp to read some information from an external device. Therefore I link snmp3r.lib and socket3r.lib so I am
able to use function snmp_open (), ....
There is no problem with the function itself. The problem is, the DATA memory is increasing all the time!!
Is there any update or other solution about this problem??
(using tcp/ip version 5.1)
BR Ulrich
Attachment: HTML sf-attachment-mime35685 3.48 KB
Re: memory leak snmp
Hello Ulrich,
The snmp_open() call uses malloc() to allocate memory for internal data. Don't you forget to call snmp_close()? If not
then can you post here tarball with minimal working example that illustrates the problem?
14 нояб. 2017 г., в 13:48:12, Mailaender, Ulrich <community-noreply@qnx.com> написал:
> Hello QNX admins,
 able to use function snmp_open (), ….
> BR Ulrich
RE: memory leak snmp
Hi Oleg,
I try to do a simple program but this takes time. So in the meantime a short description of the program
init_mib()
for ( ... )
	snmp_synch_setup ();
	if ( snmp_open (...))
		snmp_pdu_create (...);
		read_objid (...);
		snmp_add_null_var (...);
		snmp_synch_response (...);
		snmp_free_pdu (...);
		snmp_close (...);
Regards
Ulrich
From: Олег Большаков [mailto:community-noreply@qnx.com]
Sent: Wednesday, November 15, 2017 11:49 AM
To: general-qnx4@community.qnx.com
Subject: Re: memory leak snmp
Hello Ulrich,
> Hello QNX admins,
> BR Ulrich
General
http://community.qnx.com/sf/go/post118204
To cancel your subscription to this discussion, please e-mail general-qnx4-unsubscribe@community.qnx.com
Re: RE: memory leak snmp
Hi Oleg,
I have done some tests. If I slow down the for loop, no memory leak appears.
So I simply add a delay of 100ms, and everything is ok now.
Regards
Ulrich
Hi Ulrich,
It seems a bit strange, but if it's okay for you then I won't check it.
27 нояб. 2017 г., в 13:47:22, Ulrich Mailänder <community-noreply@qnx.com> написал:
> Hi Oleg,
> Regards
> Ulrich
> http://community.qnx.com/sf/go/post118241
