Forum Topic - Net.rtl8169 and Video lockup:
Group:
I have a Dell T20 with an rtl8169 network card  I am running qnx4.25 on the system work fine but if the video cable is
pulled out it locks up the server.  I have been able to track the lock up to the starting of the Network driver Net.
rtl8169.  Before the network driver is started you can unplug and plug in the video but after you start the driver the
server will lock once unplugged.
Re: Net.rtl8169 and Video lockup
Hi Michael,
Do you launch Photon graphics? What graphics driver do you use? Please send me output of following commands:
show_pci -vvv
sin irq
sin arg
sin ver
25 мая 2016 г., в 17:26:38, Michael Constanzo <community-noreply@qnx.com> написал:
> Group:
> http://community.qnx.com/sf/go/post116333
RE: Net.rtl8169 and Video lockup
The video will lock up in either environment, in the council environment before starting Photon and in Photon as well.
I have tried both the Pg.flatdc and Pg.flated32.
From: Олег Большаков [mailto:community-noreply@qnx.com]
Sent: Friday, May 27, 2016 6:25 AM
To: general-qnx4@community.qnx.com
Subject: Re: Net.rtl8169 and Video lockup
Hi Michael,
show_pci -vvv
sin irq
sin arg
sin ver
> Group:
General
http://community.qnx.com/sf/go/post116347
Attachment: Text crt.1 2.64 KB Text showpci 22.81 KB Text sinarg 1.5 KB Text sinirq 647 bytes Text sinver 863 bytes
If you are running in text mode, does the lockup still occur, or only when
running Photon? Does the lockup only occur while starting the driver or
does the lockup remain once the network driver is running?
On 2016-05-27, 9:49 AM, "Constanzo, Michael" <community-noreply@qnx.com>
>before starting Photon and in Photon as well.  I have tried both the
>-----Original Message-----
>Hi Michael,
>show_pci -vvv
>sin irq
>sin arg
>sin ver
>Respectfully,
>Oleg
>написал:
>> Group:
>>the system work fine but if the video cable is pulled out it locks up
>>the Network driver Net.rtl8169.  Before the network driver is started
>> General
>General
>General
>http://community.qnx.com/sf/go/post116349
Hugh:
	1. If you are running in text mode, does the lockup still occur, or only when running Photon?
		Yes it occurs in either mode.
	2. Does the lockup only occur while starting the driver or does the lockup remain once the network driver is running?
		Once you start Net.rtl8169, if the video cable is unplugged the server will lock up, before this diver is started the
video will not lock up if you pull the video cable.
Mike
From: Hugh Brown [mailto:community-noreply@qnx.com]
Sent: Monday, May 30, 2016 10:55 AM
If you are running in text mode, does the lockup still occur, or only when running Photon? Does the lockup only occur
>environment before starting Photon and in Photon as well.  I have tried
>Hi Michael,
>show_pci -vvv
>sin irq
>sin arg
>sin ver
>Respectfully,
>Oleg
>написал:
>> Group:
>>on the system work fine but if the video cable is pulled out it locks
>>of the Network driver Net.rtl8169.  Before the network driver is
>>driver the server will lock once unplugged.
>> General
>General
>General
General
http://community.qnx.com/sf/go/post116370
Mike,
The only thing that I see that is common between the Ethernet controller
and the video controller, is the IRQ 11. Is there a setting in the BIOS of
your machine where you can change the IRQ of either the video controller
or the Ethernet controller so that they are not on the same IRQ?
Thanks, Hugh.
On 2016-05-31, 8:58 AM, "Constanzo, Michael" <community-noreply@qnx.com>
wrote:
>Hugh:
>will lock up, before this diver is started the video will not lock up if
>Thanks
>Mike
>when running Photon? Does the lockup only occur while starting the driver
>>Hi Michael,
>>show_pci -vvv
>>sin irq
>>sin arg
>>sin ver
>>Respectfully,
>>Oleg
>>написал:
>>> Group:
>>> General
>>General
>>General
>>To cancel your subscription to this discussion, please...
