Re: QNX 4.25 and Logitech K400r USB keyboard with touch pad
11/13/2015 12:26 PM
post114999
Hi Joseph,
I should get the same keyboard next week, so I’ll test it and post here my results.
12 нояб. 2015 г., в 1:16, joseph kocsis <community-noreply@qnx.com> написал:
> Thanks for your reply Oleg.
> Attached are the outputs of usb -v and usb -vvv.
> Input has failed to get the touchpad working with the following arguments:
> Input msys fd -d/dev/usbmouse0 &
> Input msoft fd -d/dev/usbmouse0 &
> Input generic fd -d/dev/usbmouse0 &
> http://community.qnx.com/sf/go/post114968
> <usb-vvv.txt><usb-v.txt>
11/19/2015 4:40 AM
post115066
Hi Joseph,
I’ve got the similar keyboard and I’ve looked deeper into the issue. It seems that mouse protocol is different than
that is supported in devu-mouse. So I should update the devu-mouse to support the protocol.
Another solution is to use keyboard in compatible mode and do not launch io-usb for the keyboard. Does it work for you?
12 нояб. 2015 г., в 1:16:09, joseph kocsis <community-noreply@qnx.com> написал:
