Forum Topic - Siemens IPC 677D:
Siemens IPC 677D
We have used the Siemens IPC 677C successfully in the past with QNX 4.25 but now it is obsolete and has been replaced
with the Siemens IPC 677D. These units are very expensive so we would like to know before purchasing that they will
indeed work with QNX 4.25.
The specification is:
Celeron G1820TE (2C/2T, 2.2GHz, 2MB Cache)
250 GB HDD SATA
2 GB DDR3 1600 DIMM
2x PCI
HD Graphics on board (Xeon, i3: HD4600)
RAID-Controller on board
Any ideas?
Pete Mackereth
Re: Siemens IPC 677D
Hi Pete,
I didn’t find detailed hardware specification for IPC 677D. To get a theoretical conclusion about compatibility I need
to know which controllers are used (with PCI IDs if available). I can say that Intel controllers (disk, network,
graphics) are more or less compatible. Other controllers can be often supported in compatible mode. I can’t say more
without detailed specification. To be sure that PC will work with QNX 4.25 the PC should be tested. If you can test it
using QNX 4 Install CD before purchasing then it will be guarantee that PC will work.
16 окт. 2015 г., в 12:06, Pete Mackereth <community-noreply@qnx.com> написал:
> Hello,
> 250 GB HDD SATA
> 2 GB DDR3 1600 DIMM
> 2x PCI
> Any ideas?
> Thanks,
> Pete Mackereth
> http://community.qnx.com/sf/go/post114667
RE: Siemens IPC 677D
Hi Oleg,
Thanks for your help.
Pete
From: Олег Большаков [mailto:community-noreply@qnx.com]
Sent: 16 October 2015 12:19
To: general-qnx4@community.qnx.com
Subject: Re: Siemens IPC 677D
Hi Pete,
> Hello,
> 250 GB HDD SATA
> 2 GB DDR3 1600 DIMM
> 2x PCI
> HD Graphics on board (Xeon, i3: HD4600) RAID-Controller on board
> Any ideas?
> Thanks,
> Pete Mackereth
General
http://community.qnx.com/sf/go/post114669
Hello Oleg,
I have managed to install QNX 4 2015 on to this PC but after the reboot the keyboard and mouse do not respond at the
login prompt, obviously during the installation phase both worked as expected.
Do you have any suggestions.
Pete
Hi Pete,
> Hello,
> 250 GB HDD SATA
> 2 GB DDR3 1600 DIMM
> 2x PCI
> Any ideas?
> Thanks,
> Pete Mackereth
General
Hi ‎Pete,
What type of keyboard and mouse do you use? ‎Do you mean console or Photon login?
Отправлено с моего смартфона BlackBerry 10.
  Исходное сообщение
От: Pete Mackereth
Отправлено: четверг, 17 декабря 2015 г., 18:20
Кому: general-qnx4@community.qnx.com
Ответить: general-qnx4@community.qnx.com
Тема: RE: Siemens IPC 677D
Hello Oleg,
Pete
Hi Pete,
> Hello,
> 250 GB HDD SATA
> 2 GB DDR3 1600 DIMM
> 2x PCI
> Any ideas?
> Thanks,
> Pete Mackereth
General
General
http://community.qnx.com/sf/go/post115341
Hi Oleg,
It's the USB keyboard and mouse at the console QNX login ...
Welcome to QNX 4.25
login:
Photon is not running yet.
Pete
Sent: 17 December 2015 15:57
To: Pete Mackereth <general-qnx4@community.qnx.com>
Hi ‎Pete,
  Исходное сообщение
От: Pete Mackereth
Hello Oleg,
Pete
Hi Pete,
> Hello,
> 250 GB HDD SATA
> 2 GB DDR3 1600 DIMM
> 2x PCI
> Any ideas?
> Thanks,
> Pete Mackereth
General
General
General
http://community.qnx.com/sf/go/post115344
Hi Oleg,
A have little more information for you, the USB keyboard will allow me to enter the BIOS, also when the prompt "Press F1
-F4 to select drive or select partition 1?" is displayed I can press Escape or a number and it will accept these.
Pete
Hi ‎Pete,
  Исходное сообщение
От: Pete Mackereth
Hello Oleg,
Pete
Hi Pete,
> Hello,
> 250 GB HDD SATA
> 2 GB DDR3 1600 DIMM
> 2x PCI
> Any ideas?
> Thanks,
> Pete Mackereth
General
General
General
Hi Pete,
USB keyboard doesn’t supported by default in QNX 4 console. Here are available variants of usage USB keyboard in QNX 4
console:
1. Do not launch io-usb and set USB Legacy mode in BIOS setup. If you need to work with USB mass storage devices you can
 launch io-usb-ehci instead of io-usb.
2. Try to use new Dev.ansi that support USB keyboard in console. Read the discussion about that:
http://community.qnx.com/sf/discussion/do/listPosts/projects.community/discussion.qnx4_community_support.topc26371
18 дек. 2015 г., в 13:43:39, Pete Mackereth <community-noreply@qnx.com> написал:
> Hi Oleg,
F1-F4 to select drive or select partition 1?" is displayed I can press Escape or a number and it will accept these.
> Regards,
> Pete
> Hi ‎Pete,
>  Исходное сообщение
> От: Pete Mackereth
> Hello Oleg,
> Regards,
> Pete
> Hi Pete,
need to know which controllers are used (with PCI IDs if available). I can say that Intel controllers (disk, network,
> Respectfully,
> Oleg
>> Hello,
>> 250 GB HDD SATA
>> 2 GB DDR3 1600 DIMM
>> 2x PCI
>> Any ideas?
>> Thanks,
>> Pete Mackereth
>> General
> To cancel your subscription to...
Hi Oleg,
Thanks again for your help.
I am now struggling to set up the graphics driver, I have attached the results of a show_pci, do you have any idea which
 driver I should be using?
Pete
Sent: 18 December 2015 11:31
Hi Pete,
console:
> Hi Oleg,
> Regards,
> Pete
> Hi ‎Pete,
>  Исходное сообщение
> От: Pete Mackereth
> Hello Oleg,
> Regards,
> Pete
> Hi Pete,
> Respectfully,
> Oleg
>> Hello,
>> 250 GB HDD SATA
>> 2 GB DDR3 1600 DIMM
>> 2x PCI
>> Any ideas?
>> Thanks,
>> Pete Mackereth
Attachment: Text show_pci.txt 23.95 KB
Hi Pete,
The 0x8086:0x0402 device is not supported by accelerated graphics driver. You can try Pg.flat* drivers.
22 дек. 2015 г., в 13:13:46, Pete Mackereth <community-noreply@qnx.com> написал:
> Hi Oleg,
which driver I should be using?
> Thanks,
> Pete
> Hi Pete,
4 console:
can launch io-usb-ehci instead of io-usb.
> Respectfully,
> Oleg
>> Hi Oleg,
>> Regards,
>> Pete
>> -----Original Message-----
>> Hi ‎Pete,
>> Исходное сообщение
>> От: Pete Mackereth
>> Hello Oleg,
>> Regards,
>> Pete
>> Hi Pete,
>> Respectfully,
>> Oleg
>>> Hello,
replaced with...
Thanks Oleg,
It seems to be working now.
Pete
Sent: 22 December 2015 13:15
Hi Pete,
> Hi Oleg,
> Thanks,
> Pete
> Hi Pete,
4 console:
> Respectfully,
> Oleg
>> Hi Oleg,
>> Regards,
>> Pete
>> Hi ‎Pete,
>> Исходное сообщение
>> От: Pete Mackereth
>> Hello Oleg,
>> Regards,
>> Pete
>> Hi Pete,
>> Respectfully,
>> Oleg
>> 16 окт. 2015...
I'm in contact with SIEMENS and checked the 847D 1,5 years ago.
Twogether with the QNX Support from this page  I brought the PC to run using QNX4.
OK:
both Network Adapters
graphic (not accelarated! Pg.flat )
PCI slots (only one Slot can get its own Interrupt; needed for e.g. Serial Card)
USB
harddisk, CD (BIOS compatible mode)
The 847, 827, 877, 647, 627 and 677 have the same Motherboard.
They only differ in size and added Panel.
BR, Klaus
Thanks Klaus,
With help from Oleg I managed to install QNX4 on this PC and every looks OK now.
Pete
From: Klaus Pantleon [mailto:community-noreply@qnx.com]
Sent: 12 January 2016 10:11
To: general-qnx4 <general-qnx4@community.qnx.com>
OK:
PCI slots (only one Slot can get its own Interrupt; needed for e.g. Serial Card) USB harddisk, CD (BIOS compatible mode)
BR, Klaus
General
http://community.qnx.com/sf/go/post115472
