Forum Topic - Network problems :
Network problems
We are evaluating an AAEON 6614 Box PC with the following specs:
CPU	Intel® Quad Core 1.83GHz SoC N2930
Memory	DDR3L 1333 SODIMM x 1, Max. 8GB
Display	VGA x 1, HDMI x 1
Ethernet	Gigabit Ethernet, RJ-45 connector x 2 (i211)
Storage        SATA 3.0Gb/s 2.5” HDD/SSD Bay x 1 CFastTM Slot x 1 (W/ cover protection)
Starting the network driver (Net.e1000) causes Net to crash.
We see the following messages
Find device -x1539 - status 0x0
Read status 0x0
//1/bin/Net terminated (SIGSEGV) at 0015:000003D8
Net.e1000 INITIALIZATION ERROR 3
net_reg failed
If Net is started with the -v option, then "Net : Runtime Error 0035  Net: Runtime Error 0007" continually are output to
 the display.
Please help!
Attachment: Text 6614pci.txt 9.36 KB
Re: Network problems
Please try the attached driver.
>Storage        SATA 3.0Gb/s 2.5² HDD/SSD Bay x 1 CFastTM Slot x 1 (W/
>cover protection)
>Read status 0x0
>net_reg failed
>Net: Runtime Error 0007" continually are output to the display.
>Please help!
>General
>http://community.qnx.com/sf/go/post113487
>general-qnx4-unsubscribe@community.qnx.com
Attachment: Text Net.e1000 192.51 KB
Here's what I see with the supplied Net..e1000 driver. (Net is version 4.25G July 6, 2010)
Start Net from the command line, then Net.e1000 -v &
Device 1539 - Revision 3
After fix-ups FlowControl is now = 0
Forcing Speed and Duplex
M88E1000 PSCR: 0x3150
Full Duplex
Forcing 10mb
Unable to establish link!!!
Initializing Flow Control address, type and regs.
Masking off all interrupts
NVM word 0x03 is not mapped
NVM word oxo3 is not mapped
I¹ll have to take a look at the when I get a chance.
>4.25G July 6, 2010)
>Full Duplex
>Forcing 10mb
>General
>http://community.qnx.com/sf/go/post113491
RE: Network problems
Hugh,
We are in crisis mode here as our current working model stock  (now EOL)  is quickly being depleted.
Any help would be appreciated.
Nick F.
From: Hugh Brown [mailto:community-noreply@qnx.com]
Sent: Wednesday, March 04, 2015 9:13 AM
To: general-qnx4@community.qnx.com
Subject: Re: Network problems
>4.25G July 6, 2010) Start Net from the command line, then Net.e1000 -v
>& Device 1539 - Revision 3 After fix-ups FlowControl is now = 0 Forcing
>Speed and Duplex
>Full Duplex
>Forcing 10mb
>General
General
http://community.qnx.com/sf/go/post113493
To cancel your subscription to this discussion, please e-mail general-qnx4-unsubscribe@community.qnx.com
Unfortunately I’m busy with very high priority work right now, so cannot
look at anything else.
Your best bet is to contact your sales rep to escalate this problem.
On 2015/3/4, 9:21 AM, "Nick Fagan" <community-noreply@qnx.com> wrote:
>Hugh,
>Thanks,
>Nick F.
>-----Original Message-----
>>Speed and Duplex
>>Full Duplex
>>Forcing 10mb
>>General
>General
>General
>http://community.qnx.com/sf/go/post113494
How are you starting the Ethernet card driver? I have a laptop that had a similar problem and I ended up manually
starting the driver using the options to specify the vendor and the ID. Then after running that I put in a sleep 5
command. for some reason it takes a little longer for the driver to finish initializing.
  Hope it helps
Hi Harry,
Here's the network starting sequence from sysinit
Net &
Net.e1000 -l1 &
 sleep 5
 netboot &
nameloc &
From: Harry Qualls [mailto:community-noreply@qnx.com]
Sent: Monday, March 16, 2015 1:35 PM
To: general-qnx4
  Hope it helps
General
http://community.qnx.com/sf/go/post113556
