Can´t boot with Fsys.ahci...
07/31/2013 8:14 PM
post103822
Hi!! I need to change the CPU where QNX4 is working, I install QNX4 on a CPU that can boot with Fsys.eide and Fsys.atapi
, I download the latest Fsys.ahci driver, System Drivers, etc., I added the -E0 option to Proc3 line, modify to Fsys.
ahci on the build file, make the image and copy to .boot, but when I tried to boot on the new machine the process stop
on the QNX Loader screen after 5 dots. It didn´t show any error message but don´t boot. I really appreciate any help.
Victor.
Re: Can´t boot with Fsys.ahci...
08/01/2013 7:26 AM
post103831
Did you change the BIOS to AHCI before you rebooted?
Hugh Brown
Software Programmer
QNX Software Systems
Office +1 613 591-0931 x 24209
| qnx.com <http://www.qnx.com/>
>CPU that can boot with Fsys.eide and Fsys.atapi, I download the latest
>line, modify to Fsys.ahci on the build file, make the image and copy to
>.boot, but when I tried to boot on the new machine the process stop on
>don´t boot. I really appreciate any help. Victor.
>General
>http://community.qnx.com/sf/go/post103822
>general-qnx4-unsubscribe@community.qnx.com
08/01/2013 10:47 AM
post103841
Hi Hugh ! Yes, I changed to AHCI on BIOS before rebooted .... I didn´t received the SIGSEV error Message, the process
seems just stop.....
08/01/2013 10:59 AM
post103846
I would check to see whether Fsys.ahci is executable and also look at the
file size of your .boot file. Mine with the Fsys.ahci driver is about
540K. Sometimes is the boot image is too large, the system won't boot.
What is the file size and date of your Fsys.ahci? Mine is dated 19 Sep
2011 and is 217128 bytes long.
>received the SIGSEV error Message, the process seems just stop.....
>General
>http://community.qnx.com/sf/go/post103841
08/01/2013 11:40 AM
post103852
Hugh this is the size and date of the Fsys.ahci that I have:
-rwxrwxrwx 1 root root 85215 Oct 24 2011 Fsys.ahci
08/01/2013 11:43 AM
post103853
I guess that that is the stripped driver. I have attached the one that I
have for you to try.
>General
>http://community.qnx.com/sf/go/post103852
08/01/2013 12:32 PM
post103858
Thanks Hugh... I used the Fsys.ahci that you send me, but it can´t boot. The screen stops at the same point (after 5
dots in the boot loader). This is the .boot file generated:
-rw------- 1 root root 540672 Aug 01 10:02
I attached the build file that I used. I really appreciate your help. Thanks...
08/01/2013 12:33 PM
post103859
And this is the Proc32 I have:
-rwxr-xr-x 1 root root 135682 Feb 15 2012 Proc32
08/01/2013 12:57 PM
post103861
Here's my Proc32.
>General
>http://community.qnx.com/sf/go/post103859
08/01/2013 1:16 PM
post103862
Hugh, I used the Proc32 that you send me, and I modify my build file to this:
sys/boot
$ boot -v
sys/Proc32
$ Proc32 -E0 -l 1 -v 3
sys/Slib32
$ Slib32
sys/Slib16
$ Slib16
/bin/Fsys
$ Fsys -f 4096 -Hdisk500
/bin/Fsys.ahci
$ Fsys.ahci
/bin/mount
$ mount -p/dev/hd0 /dev/hd0t77 /
/bin/sinit
$ sinit TERM=qnx
But the result is the same, the boot process stops after 6 dots.
08/01/2013 1:24 PM
post103863
Well then this is a BIOS or machine problem, as Proc32 isn't even being
started. When I boot my machine I get a lot more dots than 6, so it looks
as though something is going wrong with the loader when loading the image.
If an Fsys.eide image is loading, see how many dots it puts on the screen.
The level 2 loader puts out the dots and normally if something goes wrong,
it will put and error letter on the screen. The level 1 and 2 loaders use
BIOS calls to read the boot image.
>this:
>sys/boot
>$ boot -v
>sys/Proc32
>sys/Slib32
>$ Slib32
>sys/Slib16
>$ Slib16
>/bin/Fsys
>/bin/Fsys.ahci
>$ Fsys.ahci
>/bin/mount
>/bin/sinit
>$ sinit TERM=qnx
>General
>http://community.qnx.com/sf/go/post103862
08/01/2013 1:27 PM
post103865
I added the new disk to a computer who works on QNX, I went to the boot directory on the new disk and I make the boot
image (/p31/boot/images/hard.ahci.1) then I copy the image generated to /p31/.boot that is tha root od the new disk ( I
mounted the new disk on /p31). That is correct, isn´t it ?
08/01/2013 1:33 PM
post103866
You have to be careful, as building the new image will pull files from the
root directory of the host machine and not from the disk you are building
on. Rather put your build file in the /boot/build directory of the disk
that is mounted as / and once the image is built, copy it to .boot on the
new disk. Make sure that all the new files that you require are on the
disk mounted as /.
>directory on the new disk and I make the boot image
>/p31/.boot that is tha root od the new disk ( I mounted the new disk on
>General
>http://community.qnx.com/sf/go/post103865
08/01/2013 12:46 PM
post103860
The only difference in my build file is that Fsys is started with
"-Hdisk160", but that shouldn't stop the boot process.
You can add verbosity to Proc32 in your build file and see if that tells
you anything.
>The screen stops at the same point (after 5 dots in the boot loader).
>Thanks...
>General
>http://community.qnx.com/sf/go/post103858
08/01/2013 1:51 PM
post103870
Well, I tried with a different motherboard (The first one was an Intel One) and the second one that I tried was an Asus.
The problem is different on the Asus, on the Asus, after the 6 dots on the boot process, the computer resets, try to
boot again and resets again and so on...
What can I do ? Any help please....
08/01/2013 1:59 PM
post103871
Here is the boot image from my machine. Unzip the file and then copy
boot.image to /.boot. See if that boots.
>One) and the second one that I tried was an Asus. The problem is
>the computer resets, try to boot again and resets again and so on...
>General
>http://community.qnx.com/sf/go/post103870
08/01/2013 2:22 PM
post103875
No Hugh..... The same happens...
08/01/2013 2:27 PM
post103877
Well, then this is not a QNX problem. The image boots fine on my machine.
I don't know what more to say, but this definitely looks like a problem
with the BIOS, or a BIOS setting on your boards.
>General
>http://community.qnx.com/sf/go/post103875
08/01/2013 2:32 PM
post103879
Thanks Hugh... I am leaving my office now and I will be back on Monday. I will update the BIOS on the motherboard or try
with a different brand and model and I tell you what happens. Thanks again for all your help.
