Forum Topic - Net.e1000 in vmware ESXi 5.1:
vmware host of our development system was upgraded to ESXi 5.1 version.
From the same time we are experiencing problems with Net.e1000 driver. Under some conditions (remote debugging, file
copy) it logs into netinfo log following information:
- rx bad pkt length
- rx some packets missed, txing NACK
We tried to slow the communication to 100Mbit (default is 1Gbit), but it didn't help. We have also tried all the
versions of the driver available (from 13.5.2011, 29.8.2011, 13.2.2012). The same holds true for Net.i82540 driver.
Is there any newer driver to try?
Regards, PKY
Re: Net.e1000 in vmware ESXi 5.1
So did the driver work with the previous version of ESXi?
On 2012-09-28 4:25 AM, "Pavol Kycina" <community-noreply@qnx.com> wrote:
>Hello,
>Under some conditions (remote debugging, file copy) it logs into netinfo
>- rx bad pkt length
>didn't help. We have also tried all the versions of the driver available
>Net.i82540 driver.
>Regards, PKY
>General
>http://community.qnx.com/sf/go/post95908
>general-qnx4-unsubscribe@community.qnx.com
We used Net.i82540 driver in previous version of ESXi. It worked without any problem. After the upgrade the problems
started (with Net.i82540). So we tried Net.e1000 driver (which seems to be successor to Net.i82540), but the problems
remained.
version of ESXI | Net.i82540 | Net.e1000
4.x                    | OK             | N/A
5.1                    | problem     | problem
Regards, PKY
> >Hello,
> >- rx bad pkt length
> >Net.i82540 driver.
> >Regards, PKY
> >General
Well then I guess that the problem is with ESXi rather than with the
driver, as that is the only thing that has changed.
On 2012-10-02 4:23 AM, "Pavol Kycina" <community-noreply@qnx.com> wrote:
>Hello,
>any problem. After the upgrade the problems started (with Net.i82540). So
>but the problems remained.
>4.x                    | OK             | N/A
>Regards, PKY
>> >Hello,
>>netinfo
>> >- rx bad pkt length
>>it
>>available
>> >Net.i82540 driver.
>> >Regards, PKY
>> >General
>General
>http://community.qnx.com/sf/go/post95965
Yes, that's right. But I hoped for your newer magic version of the driver would be compatible with newer ESXi (which is
imposed by our IT department).
Just for the information, there are several other people probably solving the same problem:
http://www.openqnx.com/phpbbforum/viewtopic.php?f=6&t=12535 (at the end, also suggestion to use Net.ether2100)
Regards, PKY
the
> >Hello,
> >4.x                    | OK             | N/A
> >Regards, PKY
> >> >Hello,
> >>netinfo
> >> >- rx bad pkt length
> >>it
> >>available
> >> >Net.i82540 driver.
> >> >Regards, PKY
> >> >General
> >General
Well you can try this version. It has been tested with all versions of the
Intel hardware.
>would be compatible with newer ESXi (which is imposed by our IT
>department).
>the same problem:
>Regards, PKY
>> >Hello,
>>without
>>So
>> >4.x                    | OK             | N/A
>> >Regards, PKY
>>wrote:
>> >> >Hello,
>>version.
>>driver.
>> >>netinfo
>> >> >- rx bad pkt length
>>but
>> >>it
>> >>available
>> >> >Net.i82540 driver.
>> >> >Regards, PKY
>> >> >General
>> >General
>General
>http://community.qnx.com/sf/go/post95968
Attachment: Text Net.e1000 177.54 KB
Thanks, but it doesn't work. Here is the log:
14:53:32 1   Status 1518   (4621) e1000 ( rx) Bad Pkt Lenght
14:53:32 1   Status 20144  (291)
14:53:32 1   Status 16258  (292)
14:53:32 1   000800 000000 (293)
14:53:32 1   000C29 C9F030 (4628) e1000 ( rx) some packets missed, txing NACK
14:53:32 1   Status 20144  (1099)
14:53:32 1   000800 000000 (1099)
14:53:33 1   Status 20144  (291)
14:53:33 1   Status 16258  (292)
14:53:33 1   000800 000000 (293)
14:53:33 1   000C29 C9F030 (4628) e1000 ( rx) some packets missed, txing NACK
14:53:33 1   Status 20144  (1099)
14:53:33 1   000800 000000 (1099)
14:53:33 1   Status 1518   (4621) e1000 ( rx) Bad Pkt Lenght
14:53:34 0   Status 2      ( 35) NET       logical node not in node map
14:53:34 0   Status 2      (  7) NET ( tx) failed (vc_attach ctrl pkt)
14:53:34 1   Status 20144  (291)
14:53:34 1   Status 16258  (292)
14:53:34 1   000800 000000 (293)
14:53:34 1   000C29 C9F030 (4628) e1000 ( rx) some packets missed, txing NACK
14:53:34 1   Status 20144  (1099)
14:53:34 1   000800 000000 (1099)
14:53:34 1   Status 1518   (4621) e1000 ( rx) Bad Pkt Lenght
> Intel hardware.
> >department).
> >the same problem:
> >Regards, PKY
> >> >Hello,
> >>without
> >>So
> >> >4.x                    | OK             | N/A
> >> >Regards, PKY
Have you contacted VMWare to what is different with this release? As I
said, this driver has been tested with all Intel hardware and it works
without any problems.
>NACK
>NACK
>NACK
>>the
>> Intel hardware.
>>driver
>> >department).
>>solving
>> >the same problem:
>>end,
>> >Regards, PKY
>>wrote:
>> >> >Hello,
>> >>without
I will try to follow wmvare support route as suggested.
Thanks, PKY
> >NACK
> >NACK
> >NACK
> >>the
> >> Intel hardware.
> >>driver
> >> >department).
> >>solving
> >> >the same problem:
> >>end,
> >> >Regards, PKY
> >> >> Well then I guess that the problem is with ESXi rather than...
Is there a difference in the network device IDs between the previous
version of ESXi and the current version? The output of show_pci from both
might help.
On 2012-10-02 9:11 AM, "Pavol Kycina" <community-noreply@qnx.com> wrote:
>Thanks,
>Thanks, PKY
>>txing
>> >NACK
>>txing
>> >NACK
>>txing
>> >NACK
>>of
>> >>the
>> >> Intel hardware.
>> >>driver
Vendor ID      = 8086h, INTEL CORPORATION
Device ID      = 100fh,
this is the same for both old and new ESXi.
The only difference seems to be interrupt line, which used to be 10, now it's 11.
Regards, PKY
> might help.
> >Thanks,
> >Thanks, PKY
> >>txing
> >> >NACK
> >>txing
> >> >NACK
> >>txing
> >> >NACK
Well maybe there are other devices also on IRQ 11 that are affecting the
driver throughput. USB devices in particular can cause problems.
On 2012-10-03 3:33 PM, "Pavol Kycina" <community-noreply@qnx.com> wrote:
>Hello,
>Device ID      = 100fh,
>it's 11.
>Regards, PKY
>>both
>> might help.
>> >Thanks,
>> >Thanks, PKY
>>I
>>works
>> >>txing
>> >> >NACK
>> >>txing
>> >> >NACK
>>map
>> >> >14:53:34 0   Status 2      (  7) NET ( tx) failed (vc_attach...
