Forum Topic - TCP/IP 5.1 mount_nfs:
I would like to mount a network share with mount_nfs.
TCP/IP 5.1
If I run the command as a user I got the following message:
  - Bad MNT RPC: RPC: Authentication error; why = Client credential too weak
If I run the command as root I got the message:
 - servername:/.... on mountpoint:  No such process.
TCP/IP 4.25
as a user I got the same error message as with 5.1
as root everything is ok. I have full access to the share.
What does the message - No such process - mean?
Is it not possible to mount a share as root in 5.1?
Thanks in advance
Norbert
Hi Norbert,
Please, be sure that you launched NFSfsys in TCP/IP 5.1.
> TCP/IP 5.1
> TCP/IP 4.25
> Thanks in advance
> Norbert
> http://community.qnx.com/sf/go/post92086
Re: TCP/IP 5.1 mount_nfs
Hi Oleg,
thank you for your quick response!
Now everything is working well  and I can mount the share.
Regards
Norbert
