Re: Proc32 v4.25R new option -E0
02/16/2012 5:45 AM
post91631
Hi Andrés,
I don't think that Proc32 option -E0 would have adverse effect on your
system but unfortunately it wouldn't help you.
In your situation I only can recommend to try latest Net drivers or try
another network hardware if it is possible.
To clarify situation with new Proc32 option -E0:
You should use -E0 option only if you can't run QNX because drivers
(Fsys drivers, io-usb, Net drivers) terminates by SIGSEGV (in most
cases at 00D1:XXXXXXXX) when they try to detect PCI devices.
Pavel
> We have a server in which falls the Net
> Case: http://community.qnx.com/sf/go/post90417
> It may be also one of the cases?
> If not you can have some adverse effect?
> thank you very much!,
> Andres
> http://community.qnx.com/sf/go/post91600
