Forum Topic - QNX 4.25 and Intel Q965/Q963 Video :
I am having an issue with this onboard video card and running photon.  I have downloaded the newest versions of both
crttrap.list and Pg.i830.  I also followed the directions from wiki3719 on installing graphics drivers.
I also used the commands "crttrap clear" and "crttrap trap" after updating crttrap.list and Pg.i830.  When I launch
photon the screen goes black and the monitor then goes to sleep.  This occurs with both an LCD and CRT monitor. I can
kill photon with CTRL+ALT+SHIFT+BACKSPACE and bring it back to the command line.   I've included files for show_pci -vv,
 sin ar, sin ver and sin ir as well as the /trap/crt file.  I added the first line to the /trap/crt file or otherwise
the system would freeze and require a restart.  Is there something I am missing from the steps?  Thank you.
Attachment: Compressed file Log Files.zip 5.95 KB
Re: QNX 4.25 and Intel Q965/Q963 Video
Hi Brad,
Does this problem occurs in the QNX 6.5.0 with devg-i830 driver?
Also please try to run the Photon with other video modes and the Pg.flat driver.
Andrey.
Well I was able to get it working by changing to a lower resolution and colour quality.  The weird thing is that I was
able to change it back to the 1280x1024 and 32 bit and it worked.  Thanks for the help.
Well looks like I spoke too soon.  It turns out that in the crt.64 file if I enable the flatdc32 driver and then launch
Photon nothing launches.  The monitor goes black but doesn't go to sleep. If I then slay Photon and comment out the
flatdc32 driver and use the Pg.i830 and Photon launches no problem.
I am not able to use QNX 6.5.0 with devg-i830 driver, I only have QNX 4.25.  I've attached the newer crt.64 file to show
 what I am using.
Attachment: Text crt.64.txt 11.74 KB
Hi Brad,
I think that the Pg.i830 is preferred driver. So if it works you should use
it.
The QNX4 Pg.i830 is a port of QNX6 devg-i830.so. So Andrey just asked you to
test how QNX6 is working on your HW. QNX6 evaluation is freely available at
www.qnx.com .
enable the flatdc32 driver and then launch Photon nothing launches.  The
out the flatdc32 driver and use the Pg.i830 and Photon launches no problem.
I've attached the newer crt.64 file to show what I am using.
> http://community.qnx.com/sf/go/post90673
