Re: I want to test new Fsys.ahci driver
11/14/2011 7:44 AM
post90073
The qnxboot.144.2011 image doesn't have a file system, it contains raw
encrypted image so you can't mount it. The qnxboot.144.2011 is a part
of Product Suite environment and there is no simple way to rebuild it.
I suppose that Fsys.ahci will be included to Product Suite 2012 and
qnxboot.144.2012 will contain it.
If you want to test new Fsys.ahci driver the easiest way is to prepare
your own bootable usb-flash or floppy with the Fsys.ahci.
Pavel
> When I try to test new Fsys.ahci driver, I found that I need to add Fsys.ahci driver into qnxboot.144.2011 floppy
image file. After boot standart QNX4 CD I have only Fsys.aha2scsi, Fsys.aha4scsi, Fsys.aha7scsi, Fsys.amdscsi, Fsys.
atapy, Fsys.floppy, Fsys.mitsumi, Fsys.ncr8scsi, Fsys.umass drivers.
> Mounting qnxboot.144.2011 as loop device gave me absolutely messed and meaningless filenames in mount point directory.
Very strange.
> How can I rebuild qnxboot.144.2011 file?
> http://community.qnx.com/sf/go/post90068
02/28/2012 5:30 AM
post91830
