Forum Topic - Can't run USB twice:
Can't run USB twice
I'm running the latest USB stack, v2.00 "J"
Problem:  I can only run it one time, then cannot run it again.  Second attempt, I get a resource busy error.
My USB script is:
io-usb-ehci -vvv &
sleep 5
Fsys.umass -v fsys -l -n Direct-Access=usb &
sleep 3
mount -p /dev/usb0
sleep 10
Fatfsys
And this script file mounts the USB drive as /dos/c.
I have tried every combination from umounting and deleting the mount points to slaying things in reverse order.  The
best I can do is when I try to re-run the above script, Fsys.umass gets a resource busy error.
What am I doing wrong?
Re: Can't run USB twice
Hi Jeffrey,
Your mount sequence is correct. Most interesting is how you perform unmount.
In your case I would recommend you to try the following unmount sequence:
slay Fatfsys
sleep 8
umount /dev/usb0
rm -f /dev/usb0  # if you have several /dev/usbN devices try rm -f /dev/usb*
sleep 3
slay io-usb-ehci
If this sequence would not help please provide additional information
about you system (output of the following utilities):
sin ver
sin ar
sin ir
sin
ls /dev/  (before launching mount script)
ls /dev/  (after mount script)
sin (after unmount script)
Pavel
> My USB script is:
> io-usb-ehci -vvv &
> sleep 5
> sleep 3
> mount -p /dev/usb0
> sleep 10
> Fatfsys
> http://community.qnx.com/sf/go/post89413
Thanks.  This works perfectly!  I must have been tired that day.
What I did was to create two scripts.  The first is GO_USB.  It does all the stuff in the umount sequence, then all the
stuff in mount sequence.  The second is STOP_USB, it only does the umount sequence.
I tested with a bunch of different USB sticks and sequences and they all worked.  I will try with other machines around
the office and see if it fails.
Thanks a bunch for the help!
~ Jeff
