Forum Topic - Net.e1000 and PCI device 0x1502: (9 Items)
Dear QNX4 supporters,
does someone already had the Intel Gigabit Chip with PCI device ID 0x1502 tested with Net.e1000?
I have an actual Lenovo T520 laptop in front of me with exactly these network chip.
When I look inside the Net.e1000 driver with spatch it seems that these device ID should be supported.
I'm using the Net.e1000 from May 2011 and  the driver seems to start ("-vvv" output) but there is an error message:
"ERROR: Flash registers not mapped
NVM Initialization Error"
br,
Klaus
Re: Net.e1000 and PCI device 0x1502
The driver needs to be updated, so once it is updated I¹ll send you a new
version.
> chip.
> br,
> Klaus
> http://community.qnx.com/sf/go/post88319
QNX Software Systems Limited.   (613) 591-3579           (fax)
Kanata, Ontario, Canada.
K2M 1W8
Please try the attached driver and let me know if it works.
Thanks, Hugh.
> chip.
> br,
> Klaus
K2M 1W8
Attachment: Text Net.e1000 244.7 KB
Thanks Hugh for the fast response!!
the driver is starting up correctly and I see the MAC using 'netmap' and 'netinfo -L1'.
But there are no packages going out on the ethernet interface. I see no packets using 'netinfo -L1'  and also using
netinfo the 'Media Rate' is '0'.
On a PC connected directly to the QNX node I see also no packets using automap or entering a MAC address in the netmap
and make a sin to that node number.
br,
Klaus
If I slay and restart the Net.e1000 there is following error message coming:
MDI write did not complete
PHY Initialization Error
init_phy_params failed
br, Klaus
OK, I¹ll take a look at it and get back to you.
Thanks, Hugh.
> br, Klaus
> http://community.qnx.com/sf/go/post88345
K2M 1W8
Please try the attached driver and let me know if it works OK.
Thanks, Hugh.
> br, Klaus
K2M 1W8
Attachment: Text Net.e1000 158.61 KB
Thanks Hugh for the driver update.
I tested today and it seems to work. Even netinfo shows all necessary information.
Klaus
Good news!
Thanks, Hugh.
> information.
> Klaus
> http://community.qnx.com/sf/go/post88527
K2M 1W8
