03/22/2011 5:17 AM
post84157
Hi Oleg,
the QNX6.5 CD is booting withou any problem and I can run the system from CD.
03/25/2011 5:34 AM
post84245
Hi Klaus,
Unfortunately, I don't have Intel AMT PC here, so more time will be
required to reproduce and resolve this issue. I'll contact you when here
will be any news.
> Hi Oleg,
> locally everything is working fine.
> I can mount the ISO if I use a VMWare and I can burn the ISO on CD and
> use it in any PC. The ISO is a bootable (-b bootimage) ISO with long
> filenames (-l),leading dots (-L) and RockRidge (-R) in the filesys. No
> Joliet.
> The call is:
> mkisofs -o /tmp/pantest.iso -b bootimage -l -L -R /CD_DIR
> I also tried now without RockRidge but also without success.
> If I use the 2010 QNX installation the "Auto-detecting Hardware ..."
> is working properly at the beginning. But after detection of hardware
> the installer is waiting 30 seconds for the /dev/cd0.0 and have no
> success to access it. Therefore I cant continue the installation at
> his point and I assume that there is the exactly same problem the
> cause.
> Greetings from a still alive QNX4 user;)
> Klaus
> http://community.qnx.com/sf/go/post84153
