Forum Topic - fdisk shows incorrect geometry when booting QNX4.25 off USB stick:
I am trying to create a QNX4.25  install off a bootable 4GB USB for an x86 PC. I am using the 2009 release. I have the
latest (2010) USB stack. Have also tried with earlier stack.
I boot to a shell and start the IDE drive through "disktrap start"
Running "fdisk" at this point shows totally incorrect HD geometry. I proceed to create a partion, copy the loader and
make the partion bootable anyway. Then dinit the partiton and copy on a fairly standard boot image. When attempting to
then boot off the disk the primary boot loader is not seen and be HD becomes unbootable
Are there any know issues using fdisk in this way ??
I can successfully create a QNX4.25 install on the same system off floppy. After booting off floppy "fdisk" shows
correct geometry.
Can also successfully create a QNX6.3 install off USB
Re: fdisk shows incorrect geometry when booting QNX4.25 off USB stick
Hi Mark,
First of all please make sure that you use the latest fdisk. What driver
is starting after disktrap? What type of disk do you use?
Here are several tips for this case:
1. Don't use disktrap, but start driver manually. Use the latest
Fsys.atapi for EIDE disks.
2. Zero the partition table and then restart the disk driver. Use fdisk -z
for this.
3. Set correct geometry via the disk driver options.
Don't use all these tips at once, but start from the first.
> x86 PC. I am using the 2009 release. I have the latest (2010) USB
> proceed to create a partion, copy the loader and make the partion
> boot image. When attempting to then boot off the disk the primary boot
> floppy. After booting off floppy "fdisk" shows correct geometry. Can
> http://community.qnx.com/sf/go/post66043
Thanks for that Oleg, was very helpful.
Updating to the latest "Fsys.atapi" and manual start solved startup problems on a number of different systems (we have a
 mixture of solid state and HD IDE drives).
Through the BIOS I forced LBA (where I could)  for the HD, rather than using an "Auto" setting
Deleted the partitons "fdisk <drv> delete -a"
Found that if I used fdisk to add QNX boot partiton at 100% of the drive, loading the boot image failed. Partioned to 99
% and load was successful (not sure why)
Fdisk shows more reasonable drive geometry, but more importantly now seems to write the partioning info and primary boot
 loader using correct addressing on the HD.
Hi Mark,
Try to start the Fsys.atapi with "fsys -i" options and after this use
fdisk.
> problems on a number of different systems (we have a mixture of solid
> drive, loading the boot image failed. Partioned to 99% and load was
> seems to write the partioning info and primary boot loader using
> http://community.qnx.com/sf/go/post66269
I've bumped into the same problem and am retrying with today's Fsys.atapi release.
I have an 80GB disk with a zeroed-out MBR, and I've constructed a bootable floppy and bootable USB stick that are nearly
 identical. The only difference is that the floppy's boot image includes Fsys.floppy, and the USB stick has io-usb and
Fsys.umass instead.
When I boot from floppy, fdisk shows correct disk geometry, i.e. 255 heads 63 sectors.
When I boot from USB, fdisk shows incorrect geometry, i.e. 64 heads 32 sectors.
Specifying "fsys -i" to Fsys.atapi seems to make no difference.
Manually specifying disk geometry to Fsys.atapi is not a viable option because I don't know the disk size in advance. If
 it's less than about 4GB, then the BIOS will likely *not* have chosen 255 heads 63 sectors.
Any suggestions?
I've also noticed something weird...
# fdisk /dev/hd0 info
(in summary: 76319 cylinders, 64 heads, 32 sectors)
# fdisk /dev/hd0 add t77 1024
0: (77) beg(h=1,s=1,c=0) end(h=63,s=224,c=255) off=32, size=2097120
What's with the wacky end geometry? Is this just a display bug?
Sector 224 should be impossible; that field is only 6 bits long.
(Maybe that's it; "0xe0 0xff" should be interpreted as s=32 c=1023, not s=224 c=255 ... right?)
I've been working with a rather old version of dinit (dated 1997) but the newer CD images contain a version dated 2007.
This appears to support a "-8" parameter, to install an extended int 13 loader.
The "old" int 13 interface requires CHS addresses, so a geometry mismatch will break it.
The "extended" int 13 interface operates on LBA addresses, so geometry shouldn't matter. Of course, this isn't supported
 on very old PCs. But if it works on any system that can boot from USB, then this might very well solve my problem!
However, specifying the "-8" parameter seems to cause dinit to exit without doing anything. That is, it doesn't display
a message, but it also doesn't initialize the filesystem.
# dinit -8 -q -h /dev/hd0t77
What am I doing wrong?
It seems that the "-8" option isn't needed. Simply using the new version of dinit seems to solve the problem. Maybe it's
 automatically installing an extended int13 loader. My test system now boots properly even though the partition table
and BIOS disagree on disk geometry.
Also, there's still the "fdisk info" CHS output oddity. Again, I believe that this is strictly cosmetic, but it would
still be nice to see this fixed. I'm using the 2009 July 14 release.
Hi Graham,
What do you mean by "CHS output oddity"?
> version of dinit seems to solve the problem. Maybe it's automatically
> even though the partition table and BIOS disagree on disk geometry.
> believe that this is strictly cosmetic, but it would still be nice to
> http://community.qnx.com/sf/go/post85740
Hi Graham,
Attaching updated fdisk. Please, test it.
Attachment: Text fdisk.20110519.tar.gz 46.68 KB
