RE: second Fsys.atapi on same int
08/02/2010 8:42 AM
post61339
Hi Oleg,
sorry but I dont have the hardware any more on my desktop.
As soon as I have the next Dell 6510 I will give you the "sin ??" info.
The proposal with an USB2PCMCIA adapter I already tested and it is much much faster.
But I want to offer the service persons of my company a solution without any add on hardware.
These add on hardware I cannot control. The vandor and type of laptop is good to control.
Freundliche Grüße / Best regards
Klaus Pantleon
Softwarestandardisierung, Hardwarestandardisierung, Fernwartungslösungen
_________________________________________________
Voith Paper Automation GmbH & Co. KG
- prf
St. Pöltener Straße 43
89522 Heidenheim, Germany
Tel +49 7321 37 2137
Fax +49 7321 37 6109
Mobile +49 172 7394158
Klaus.Pantleon@Voith.com
http://www.voithpaper.com
http://www.fieldinstruments.voithpaper.com
Handelsregister Ulm, HRA 661188
Sitz der Gesellschaft: Heidenheim
Geschäftsführung:
Dr. Antti Kaunonen (Vorsitzender), Ingolf Cedra, Alexander Kienle
Persönlich haftende Gesellschafterin: Voith Paper Automation Verwaltungs GmbH, Reg. Gericht Ulm, HRB 661292
From: Oleg Bolshakov [mailto:community-noreply@qnx.com]
Sent: Monday, August 02, 2010 12:37 PM
To: general-qnx4
Subject: Re: second Fsys.atapi on same int
Hi Klaus,
Sorry for delay with answer. I need output of
sin ar
sin ver
sin ti
sin ir
sin pr
show_pci -vvv
pc-pin
when your system works slow. Also I can't find the Dell D6510 specification, so post it (or link to it) here. May be using a USB stick instead of PCMCIA flash drive is a better idea.
> Hi Oleg,
> I made a test to extract the problem as most clear as I can:
> 1) Boot over the network
> 2) start Fsys.atapi for cd
> 3) start Fsys.atapi for hd
> 4) checked speed for cd and hd
> 5) stopped Fsys.atapi
> 6) Start Fsys.atapi for cd and hd
> 7) checke speed for cd and hd
> This test I made for the Dell and for a VMWare and attached the
> terminal aoutput in the following. Also I made the "sin ar" for both
> environment before starting the testprocedure. You will see that
> theses effect is not reproducable in VMWare. Please tell me at wht
> time in teh testprocedure you want the "sin ??" calls.
> sin ar for Dell:
> PID USER NAME ARGUMENTS
> 1 System Proc32 -l 179 -p2000 -P26
> 2 System Slib32
> 4 System Net -n500 -m 2 1 000C29 1EEDBD
> 5 System Net.e1000 -I0 -l1
> 7 System Not available.
> 491 System Pipe
> 509 System Dev -n 100
> 527 System Dev.ansi -Q -n 4
> 626 System tinit -t /dev/con1 /dev/con2 /dev/con3 /dev/con4
> /dev/config 636 System /bin/nameloc
> 639 System /bin/nameloc
> 1306 System /bin/login -p
> 1321 System /bin/login -p
> 1355 System /bin/login -p
> 1381 System /bin/login -p
> 5051 root -sh
> 5781 root sin ar
> sin ar for VMWare:
> 1 System Proc32 -l 182 -p2000 -P26
> 2 System Slib32
> 5 System Net.ether2100 -I0 -l1
> 489 System Pipe
> 507 System Dev -n 100
> 525 System Dev.ansi -Q -n 4
> 541 System Dev.ser -b38400 -t14
> 636 System tinit -t /dev/con1 /dev/con2 /dev/con3 /dev/con4
> /dev/config 646 System /bin/nameloc
> 649 System /bin/nameloc
> 1308 System /bin/login -p
> 1333 System /bin/login -p
> 1357 System /bin/login -p
> 1390 System /bin/login -p
> 2335 root -sh
> 2826...
