Forum Topic - multicast needs a gateway:
Can't do multicast if a gateway isn't defined.   I don't know about the rules, but looking around on the web it seems
some stack implementation (FreeBSD) don't need this, while other do.
May I suggest adding some documentation indicating this behavior.
- Mario
Re: multicast needs a gateway
The behaviour is to use normal routing to determine which interface
to send on if the IP_MULTICAST_IF socket option isn't used. ie a
gateway isn't strictly necessary.  You can have a specific route to
the multicast address and even that isn't necessary if IP_MULTICAST_IF
is used.
