Forum Topic - Number of PPP instances on same serail port :
Hi
Till now i was with assumption that PPP is only between 2 systems, used only for point to pint communcaition, and one
PPP instance will be connected to dedicated serial link.
But today i tried intantiating 2 processes on same serail port.I.e
First i did
pppd /dev/ser2 proxyarp 115200 192.168.0.200:192.168.0.210
then i did
pppd /dev/ser2 proxyarp 115200 192.168.0.200:192.168.0.220
and as part of ifconfig i got :
ppp1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1500
        inet 192.168.0.200 -> 192.168.0.210 netmask 0xffffff00
ppp0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1500
        inet 192.168.0.200 -> 192.168.0.220 netmask 0xffffff00
when i tried to attach third instance
pppd /dev/ser2 proxyarp 115200 192.168.0.200:192.168.0.230
ppp0: flags=8050<POINTOPOINT,RUNNING,MULTICAST> mtu 1500
ppp1: flags=8050<POINTOPOINT,RUNNING,MULTICAST> mtu 1500
ppp2: flags=8050<POINTOPOINT,RUNNING,MULTICAST> mtu 1500
all three got failed,
1. Is there any limit on no of virtual PPP interfaces that can be connected to a particaular serail link.
2. what woud be real need for instantiating multiplte virtaul PPP interfaces, is it that if i have RS-485 is on other
end of serail port, can i have a one to many network, where each virtaul instance can communiate with one device on 485
network ? ... send me some links where i can get data on this.
Ravi
Re: Number of PPP instances on same serail port
Attach multiple ppp instances on same serial does not sound right. Can you explain what exactly you are trying to do?
Hi
Please see attached ppt. Aim is to directly send command from A to D1, D2, D3 on their IP Addresses, for this what we
need to do in B.
1. If ppp is b/w two machines (B and C) then i used
pppd /dev/ser2 proxyarp 115200 192.168.0.200:192.168.0.210 to assign Ip address to B and C, which comunicates over
serail port.
2. From my understanding now C has to act as router, so initial thought that came to me is
- To create as many ppp process for handling D1,D2,D3 etc ..in B and C, all of which will use the same serial port.
- Since D1,D2,D3 will have already Ip assigned (ethernet port) C will act as router to forward the packets, i.e by
enabling IP forward mechanism.
But i am not sure the concept is goign to work or not. I am still trying, Let me know if i went wrong coceptually any
where, suggest me any better approach.
Ravi
destiantion is only C then what we did is enable pppd
Attachment: Powerpoint ppp_router1.ppt 20.5 KB
RE: Number of PPP instances on same serail port
No, you should only establish one ppp connection between B and C.
Both B and C will acting as a router, make sure both of them have
forwarding enabled.
The rest is just to set everyone's routing table so A knows how to goto
D[1-3], and D{1-3] knows how to reach back to A.
-xtang
> From: ravi varma [mailto:community-noreply@qnx.com]
> Sent: November 28, 2008 3:43 AM
> To: technology-networking
> Subject: Re: Number of PPP instances on same serail port
> Hi
D2,
> D3 on their IP Addresses, for this what we need to do in B.
Ip
> address to B and C, which comunicates over serail port.
thought
> that came to me is
C,
act
> as router to forward the packets, i.e by enabling IP forward
mechanism.
trying,
> Let me know if i went wrong coceptually any where, suggest me any
better
> approach.
> Thanks
> Ravi
Can
> you
> Technology
> http://community.qnx.com/sf/go/post17508
