Forum Topic - Setting a DHCP option?:
I've done some digging over the past few days and found aa good amount of info about the dhcp.client process, but I
haven't found anything that'll let me set a specific DHCP option.
For example, what if I wanted to set the value of the DHCP option 12 (hostname) in my DHCP Discover packet in order to
specify my hostname? Or use a different value for my Client Identifier (Option 61) than the one the dhcp.client process
uses by default?
I know I can use the /etc/dhcp/dhcp-options file to request additional options from the server, but how do I *set*
additional options?
Mike
RE: Setting a DHCP option?
One advantage to having source posted:
http://community.qnx.com/integration/viewcvs/viewcvs.cgi/trunk/services/dhcp
.client/dhcp.client.use?root=core_networking&rev=1&system=exsy1001&view=mark
up
	I think that covers it...
		Robert.
Sent: Thursday, May 08, 2008 4:41 PM
To: technology-networking
Subject: Setting a DHCP option?
info about the dhcp.client process, but I haven't found anything that'll let
(hostname) in my DHCP Discover packet in order to specify my hostname? Or
dhcp.client process uses by default?
options from the server, but how do I *set* additional options?
Mike
Technology
http://community.qnx.com/sf/go/post7897
Re: RE: Setting a DHCP option?
How do I get permission to view it?
RE: RE: Setting a DHCP option?
If you've created a MyQNX account, you should be able to log in and "just
see it".  If you haven't logged in, the collabnet interface is a bit bizarre
in that what you have to do is go to the repository
http://community.qnx.com/sf/scm/do/listRepositories/projects.networking/scm
Clock on the "Core Networking" button and then click on "view Commits" (left
side).  You can then click on the "Browse repository" button.
I would have thought that the link that I gave you would have taken you
straight to the use message, but, then again, I'm logged in...
	Robert.
Sent: Thursday, May 08, 2008 5:16 PM
Subject: Re: RE: Setting a DHCP option?
Technology
http://community.qnx.com/sf/go/post7900
Re: RE: RE: Setting a DHCP option?
OK, got it, thanks...
I see that you guys have added the -D option for the client ID... but what if I wanted to set the Class-ID (option 60)
as well? User Class Information (Option 77)??
You guys might want to consider adding a way to hook ANY custom DHCP option into the client application...
Thanks for the info though. Very helpful!
Mike
RE: RE: RE: Setting a DHCP option?
That feature already exits since the source is available.  You can add
whatever you want to it.
Sent: Thursday, May 08, 2008 6:18 PM
Subject: Re: RE: RE: Setting a DHCP option?
if I wanted to set the Class-ID (option 60) as well? User Class Information
(Option 77)??
Mike
Technology
http://community.qnx.com/sf/go/post7904
