System hangs with "initSocket -247" message on the console
08/01/2014 11:49 AM
post111286
hello all
I have a x86 platform running qnx 6.5.0:
$ uname -a
QNX myLSU 6.5.0 2012/06/20-13:50:45EDT x86pc x86
and io-pkt-v6-hc variant of io-pkt.
I need to mount/unmount several times a custom "devnp_" network driver into io-pkt (not a real hardware device driver,
it will register a set of virtual interfaces for intercepting/injecting software-produced packets).
This has always worked fine (and still it does) under 6.4.1 qnx version.
Under qnx 6.5.0, I often get a system hang when mounting the devnp_ module into io-pkt: platform becomes unreachable via
networking (ping does not get responses), and the local USB keyboard/console is not responding. Local monitor reports
one or more messages saying:
initSocket -247
I noticed that often the same message appears on the console when I want to shutdown the system (shutdown -b), probably
when the io-pkt process is killed.
The hang is not systematic, but it seems to me that it happens more often with io-pkt-v6-hc than with io-pkt-v4, and
also more often with my devnp_ module left symbol-unstripped than when I strips symbols out of it ! (does it make any
sense??)
So, my first question is: what does "initSocket -247" means and what should I start investigating on?
Is there some incompatibilities in network drivers binaries compiled under 6.4.1 devel env, when mounted against qnx 6.5
.0 io-pkt targets?
thanks
Davide
