Forum Topic - unable to mount packet filter LSM into io-pkt-v4-hc:
Setup: QNX running on a VM (x86), Momentics IDE 4.7
intent: develop a packet filter that can let us inspect all in/out traffic and potentially reject some.
I have read the Packet Filtering chapter from the "Core Networking with io-pkt User's Guide for Neutrino 6.3.2 or later"
.pdf. I have taken the sample code provided in there and have written a LSM by creating a QNX C Project from Momentics
with Type set to "Shared library". There is only one source file with the entry point defined as:
struct _iopkt_lsm_entry IOPKT_LSM_ENTRY_SYM(pfil) =
  IOPKT_LSM_ENTRY_SYM_INIT(pfil_entry);
int pfil_entry(void *dll_hdl, struct _iopkt_self *iopkt, char *options)
    struct pfil_head *pfh_inet;
    printf("in the entry point of the packet filter module\n");
    // saw this is another posting on Foundry 27, but this did not work for me
    //pfh_inet = pfil_head_get(PFIL_TYPE_IFT, IFT_ETHER);
    pfh_inet = pfil_head_get(PFIL_TYPE_AF, AF_INET);
    if (pfh_inet == NULL) {
    	printf("could not get pfil_head_get()\n");
        return ENOENT;
    int ret = 0;
    ret = pfil_add_hook(input_hook, NULL, PFIL_IN | PFIL_WAITOK, pfh_inet);
    ret = pfil_add_hook(output_hook, NULL, PFIL_OUT | PFIL_WAITOK, pfh_inet);
    pfh_inet = pfil_head_get(PFIL_TYPE_IFNET,0);
        return ESRCH;
    pfil_add_hook(iface_hook, NULL, PFIL_IFNET, pfh_inet);
    pfil_add_hook(ifacecfg_hook, NULL, PFIL_IFADDR, pfh_inet);
    printf("Loaded pfil hooks - this time returning 1(one) from the hook function\n" );
    return 0;
static int output_hook(void *arg, struct mbuf **m, struct ifnet *ifp, int dir)
    out_bytes += (*m)->m_len;
    return 1; // 0 means allow, 1 means block
functions input_hook(), iface_hook(), ifacecfg_hook(), deinit_module() omitted for brevity.
When I compile this, I get the following lines on the Console of the IDE:
make.exe[2]: Entering directory `C:/ide-4.7-workspace/SISIPSNetFilter/x86/so'
C:/QNX650/host/win32/x86/usr/bin/qcc -Vgcc_ntox86 -c -Wc,-Wall  -O          -DNDEBUG   -I. -IC:/ide-4.7-workspace/
SISIPSNetFilter/x86/so -IC:/ide-4.7-workspace/SISIPSNetFilter/x86 -IC:/ide-4.7-workspace/SISIPSNetFilter -IC:/QNX650/
target/qnx6/usr/include/io-pkt -IC:/QNX650/target/qnx6/usr/include       -shared -DVARIANT_so -DBUILDENV_qss  C:/ide-4.7
-workspace/SISIPSNetFilter/SISIPSNetFilter.c
C:/QNX650/host/win32/x86/usr/bin/rm -f  C:/ide-4.7-workspace/SISIPSNetFiler/x86/so/lsm-libSISIPSNetFilter.so
C:/QNX650/host/win32/x86/usr/bin/qcc -Vgcc_ntox86  -shared -Wl,-hlsm-libSISIPSNetFilter.so.1    -oC:/ide-4.7-workspace/
SISIPSNetFilter/x86/so/lsm-libSISIPSNetFilter.so    SISIPSNetFilter.o   -L . -L C:/QNX650/target/qnx6/x86/lib -L C:/
QNX650/target/qnx6/x86/usr/lib  -Wl,--rpath-link . -Wl,--rpath-link C:/QNX650/target/qnx6/x86/lib -Wl,--rpath-link C:/
C:/QNX650/host/win32/x86/usr/bin/rm -f  C:/ide-4.7-workspace/SISIPSNetFilter/x86/so/lsm-libSISIPSNetFilterS.a
C:/QNX650/host/win32/x86/usr/bin/qcc -Vgcc_ntox86 -a  C:/ide-4.7-workspace/SISIPSNetFiler/x86/so/lsm-libSISIPSNetFilterS
.a SISIPSNetFilter.o
C:\QNX650\host\win32\x86\usr\bin\ntox86-ar: creating C:/ide-4.7-workspace/SISIPSNetFilter/x86/so/lsm-libSISIPSNetFilterS
.a
make.exe[2]: Leaving directory `C:/ide-4.7-workspace/SISIPSNetFiler/x86/so'
Once the LSM is ready, I copy it to the QNX target, and attempt to mount it to the io-pkt* stack
# mount -v -T io-pkt lsm-libSISIPSNetFilter.so
Parsed: mount from [lsm-libSISIPSNetFilter.so] mount on [NULL] type [io-pkt]
mount: Can't mount / (type io-pkt)
mount: Possible reason: No such device or address
# mount -v -T io-pkt-v4-hc lsm-libSISIPSNetFilter.so
Parsed: mount from [lsm-libSISIPSNetFilter.so] mount on [NULL] type [io-pkt-v4-hc]
mount: Can't mount / (type io-pkt-v4-hc)
mount: Possible reason: Invalid argument
When I launch an instance of io-pkt-v4-hc as below:
/sbin/io-pkt-v4-hc...
Re: unable to mount packet filter LSM into io-pkt-v4-hc
If you already have an instance of io-pkt running, don't start another one without specifying the prefix option
otherwise they will stomp on each other.
Your mount command should be
mount -T io-pkt /path/to/file/lsm-libSISIPSNetFilter.so
The examples of other lsm's that omit the path are where the lsm is already in /lib/dll. Also the type needs to be io-
pkt regardless of which variant of io-pkt you are actually running. Keep an eye on slog messages by using sloginfo, io-
pkt will report if it has problems with mounts there in more detail than the simple errno that it returns to mount.
Wow, that seems to have worked....thanks!
Any way to unmount my packet filter? do i have do a "slay io-pkt-v4-hc"?
There is no way to unmount an lsm from io-pkt, you will need to slay and restart.
Ok, i did a "slay io-pkt-v4-hc" and then a /sbin/io-pkt-v4-hc -ptcpip, several things happen:
a) i lose connectivity with the Momentics IDE machine
b) i/f wm0 is again missing when i do a ifconfig
c) the browser on the QNX VM is unable to open any web site...
do i need to restart the VM?
ps: I did this - /sbin/io-pkt-v4-hc -ptcpip - because when the QNX boots up and i do a ps -ef | grep io-pkt-v4-hc, it
shows me the argument for io-pkt-v4-hc as -ptcpip
RE: unable to mount packet filter LSM into io-pkt-v4-hc
The boot process detects and mount the proper network driver. You can find out which one it is by doing pidin -P io-pkt-
v4-hc mem.  You`ll see the dll.
-----Message d'origine-----
De : Manoj Sati [mailto:community-noreply@qnx.com]
Envoyé : Thursday, February 20, 2014 11:03 AM
À : technology-networking
Objet : Re: unable to mount packet filter LSM into io-pkt-v4-hc
Technology
http://community.qnx.com/sf/go/post108938
To cancel your subscription to this discussion, please e-mail technology-networking-unsubscribe@community.qnx.com
