Forum Topic - VLAN frames transmission using packet filters:
I am trying to transmit Ethernet frames with VLAN headers using the packet filter's if_output method. I set the sockaddr
 structure sa_data arguments to hold the destination ethernet address, source address, VLAN tag, VLAN flags and the next
 header type arguments. However, I do not see any packet being transmitted on the wire. If I transmit a frame without
the VLAN fields, the transmission happens properly. Does it have to do to with the QNX stack not supporting VLAN frame
transmission or the Ethernet driver? Any insight would be helpful.
Re: VLAN frames transmission using packet filters
Have you tried actually creating a VLAN interface and configuring the VLAN ID field on it, and then doing a transmit on
that?
I did not create a vlan pseudo interface. I'll try that now. However, from the QNX help, it seems to mention that
creating the VLAN pseudo interface would fill in the VLAN header and insert it into the packet that is going out. Now,
my application is itself creating the VLAN header and the Ethernet header and trying to pass the packet directly to the
driver using the if_output call on a specific interface. In this sceanrio, is it still required to create a vlan pseudo
interface and map it to the actual interface?
It's something I haven't looked in to, but if you want to go that way then I think you will need to have the VLAN stuff
as part of the data payload rather than in the sockaddr.
Can you please post a template as to how I can add the VLAN tag as part of the payload? Or if there is some
documentation which you can point to, that would be great.
