Re: UNKNOWN COMMAND as reply from wpa_ctrl_request(cntrl,"SCAN")
12/18/2013 3:51 PM
post107636
Hi Chris,
I tried with below command with g removed,it did not create wpa_supplicant in /var/run folder. Program failed to open
interface, wpa_ctrl_open() returned NULL.
Cmd : wpa_supplicant_xxxxx /var/run/wpa_supplicant -Dxxxx -ista0 -ddt -C/var/run/wpa_supplicant &
Below command did create wpa_supplicant in var/run/ folder but now i am not able to open control interface.
wpa_ctrl_open(“/var/run/wpa_supplicant”) returned NULL!!!!!!!
Cmd : wpa_supplicant_xxxxx -Dxxxx -ista0 -ddt -C/var/run/wpa_supplicant &
I tried to start command line tool (Wpa_cli_xxxxx) with above non global wpa_supplicant
I got error: Failed to connect to Non-global ctrl-ifname
Wpa_cli_xxxxx works with global interface that I created previously. I was able to scan as well as connect to AP through
commands.
NOTE: xxxxx is third party name who supplied wpa_suppicant.
